DNP3 ALEOS Configuration Template for RV50
Is there a port configuration to use the DNP3 protocol with the RV50. The configuration directions has modbus but not DNP3.
Hi @Larry.Gelbien ,
I cannot find any information relating DNP3 support for RV50. Please consider using Modbus instead of. Let feel free share any question you have
I’m looking into using the LUA programming option in the modems to do something similar. If it doesn’t work then maybe shutters I’ll use modbus to the RTU.
If your end device is DNP then you can use the TCP/UDP over ethernet or serial to your RTU. This treats the modem as just a gateway.
