My FX30S device keeps rebooting every hour. These are the last lines written to logread before the device reboots:
Apr 17 13:59:54 fx30s user.debug lowtempfix: tmrHandler returns temperature as 32
Apr 17 13:59:54 fx30s user.info Legato: INFO | dcsDaemon[1321]/dcsCellular T=main | dcsCellular.c DcsCellularConnEventStateHandler() 257 | State of connection 1 transitioned from up to down
Apr 17 13:59:54 fx30s user.info Legato: INFO | dcsDaemon[1321]/dcsCellular T=main | dcsCellular.c le_dcsCellular_RetryConn() 1332 | Initiated retrying connection 1; retry attempt 1, backoff 1 secs
Apr 17 13:59:54 fx30s user.info Legato: INFO | dcsDaemon[1321]/dcsCellular T=main | dcsCellular.c DcsCellularConnEventStateHandler() 315 | Wait for the next retry before failing connection 1
Apr 17 13:59:54 fx30s user.info Legato: INFO | dcsDaemon[1321]/dcsDaemon T=main | dcsServer.c ChannelEventHandler() 909 | Received for channel reference 0x33 event Temporary Down
Apr 17 13:59:54 fx30s user.info Legato: INFO | dcsDaemon[1321]/dcsNet T=main | dcsNet.c net_RestoreDefaultGW() 656 | Default IPv4 GW address on interface restored
I can see that the reboot reason is Reset, User expected when I run cm info:
Device: FX30S(WP7702)
IMEI: ############
IMEISV: 8
FSN: ############
Firmware Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
Bootloader Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
MCU Version: 002.015
PRI Part Number (PN): 9907957
PRI Revision: 001.000
Carrier PRI Name: GENERIC
Carrier PRI Revision: 001.079_000
SKU: 1103882
Last Reset Cause: Reset, User Requested
Resets Count: Expected: 141 Unexpected: 5
FX30 Version: R15.1.0.004
The device is running a custom app that sends data to Azure iot hub, I can see that the app runs fine in between these reboots and the data connection is up.
How can I identify why the device is rebooting? Is it possible to disable the auto-reboot to keep the device in the faulty state and debug it?
