I can’t get my device only on the server na.airvantage.net
I have followed the documentation https://doc.airvantage.net/display/USERGUIDE/Connect+your+device until step 4 now.
When I start the agent on my device I get this output:
I have tried with three different Device ID’s now, the default, an test ID and the UID from the server (the one from the output)
The configuration file is here:
-- Copyright (c) 2012 Sierra Wireless and others.
-- All rights reserved. This program and the accompanying materials
-- are made available under the terms of the Eclipse Public License v1.0
-- which accompanies this distribution, and is available at
-- http://www.eclipse.org/legal/epl-v10.html
-- Contributors:
-- Laurent Barthelemy for Sierra Wireless - initial API and implementation
-- Cuero Bugot for Sierra Wireless - initial API and implementation
-- Default configuration file for Linux targets
local config = {}
setfenv(1, config)
server = {}
server.serverId = "AIRVANTAGE"
server.retrytimes = 10
server.retryperiod = 60
-- Determines the protocol, host, port, and optionally other things such
-- as path, user, password
--server.url = "tcp://m2m.eclipse.org:44900"
--server.url = "http://localhost:8070/device/com"
--server.url = "http://webplt-qa.anyware-tech.com/device/com"
--server.url = "http://webplt-m2m.anyware-tech.com/device/com"
--server.url = "http://edge.m2mop.net/device/com"
server.url = "tcp://na.airvantage.net:44900"
--When the device is behind a proxy this settings defines a HTTP proxy. This parameter is only relevant for HTTP transport protocol
--server.proxy must be a URL starting by "http://".
--server.proxy = "http://some.proxy.server:port"
-- Security: authentication is one of "hmac-sha1" or "hmac-md5" (or nil)
-- Encryption cannot be enabled without authentication. It's of the form
-- "<cipher>-<chaining>-<length>", where cipher must be "aes", chaining is
-- either "ctr" or "cbc", length is either "128" or "256".
-- server.authentication = 'hmac-sha1'
-- server.encryption = 'aes-cbc-128'
-- Agent auto connection policy
server.autoconnect = { }
-- server.autoconnect.onboot = true -- connect a few seconds after the Agent started
-- server.autoconnect.period = 5 -- period in minute (connect every 5 minutes)
-- server.autoconnect.cron = "0 0 * * *" -- cron entry (connect once a day at midnight)
agent = {}
agent.assetport = 9999 -- connection port, used to communicate with all the local clients
--Address on which the agent is accepting connection in order to communicate with the assets
--Pattern is accepted: can be set to "*" to accept connection from any address, by default shell accepts only localhost connection.
--agent.assetaddress = "*"
agent.deviceId = "c084a1a5779748a9b191ad2b3955a2cf"
agent.signalport = 18888 -- port used for LUASIGNAL fwk (Linux only)
-- Shell related settings
shell = {}
shell.activate = true
shell.port = 2000
shell.editmode = "edit" -- can be "line" if the trivial line by line mode is wanted
shell.historysize = 30 -- only valid for edit mode,
-- Rest related settings
rest = {}
rest.activate = true
rest.port = 8080
-- Time related settings
time = {}
-- activate Time Services: periodic polling only for now, sync can always be done using synchronize API on demand.
time.activate = false
--timezone: signed integer representing quarter(s) of hour to be added to UTC time (examples: -4 for UTC-1, 18 for UTC+5:45, ...)
time.timezone = 0
-- daylight saving time: signed integer representing quarter(s) of hour to be added to UTC time
time.dst = 0
time.ntpserver = "pool.ntp.org"
--polling period for auto time sync
--irrespective of `ntppolling`'s value, time sync is performed when the Agent boots if both `time` and `network` are activated
--if `ntppolling` is set to 0 or `nil`, no periodic time sync is done
--if set to a string value, it will be interpreted as a cron entry (cf. `timer` doc)
--otherwise, a positive number representing minutes is expected, to specify periodic time sync.
time.ntppolling = 0
-- Modem configuration
modem = {}
--modem.activate = true
--modem.pin = ""
modem.atport = "/dev/ttyS0"
modem.pppport = "/dev/ttyS0"
network = {}
network.activate = false
--network.maxfailure = 2
network.bearerpriority = {"ETH","GPRS"}
network.smsfallback = false
-- amount of time to wait before going back to the preferred bearer if connected bearer is not the first of bearerpriority list.
-- if set to nil or equals to 0 netman will never go back automatically to first bearer.
network.maxconnectiontime = 30
--network.retry = 5 --use only if network.bearer.XXX.retry not defined
--network.retryperiod = 10 --use only if network.bearer.XXX.retryperiod not defined
--network.smsfallback = "+33102345879" -- address to send outgoing sms to (e.g. server SMS reception number)
network.bearer = {}
network.bearer.GPRS = {apn = "internet-entreprise", retry = 2, retryperiod = 10, automount = true}
network.bearer.ETH = {mode = "dhcp", retry = 2, retryperiod = 10, automount = true}
--network.bearer.ETH = {mode = "static", retry = 2, retryperiod = 50, automount = true, address = "10.0.2.87", netmask = "255.255.0.0", broadcast = "10.0.255.255", gateway= "10.0.0.254", nameserver1 = "10.6.0.224", nameserver2 = "10.6.0.225"}
log = {}
log.defaultlevel = "INFO" -- default log level: can be one of NONE, ERROR, WARNING, INFO, DETAIL, DEBUG, ALL. See log.lua for details
log.moduleslevel = { }
--log.moduleslevel.GENERAL = "ALL" -- per module log level
--log.moduleslevel.SERVER = "INFO" -- per module log level
log.moduleslevel.SCHED = "INFO" -- per module log level
log.moduleslevel.TREEMGR = "DETAIL" -- per module log level
log.enablecolors = true
-- change default format for all logs
--log.format = "%t %m-%s: %l"
-- timestampformat specifies strftime format to print date/time.
-- timestampformat is useful only if %t% is in formater string
log.timestampformat = "%F %T"
update = {}
update.activate = true
--update package file name to use for local update file detection
--update.localpkgname="updatepackage.tar.lzma"
--dwlnotifperiod: number of seconds between update notification during downloads, default value is 2s.
--update.dwlnotifperiod = 30
-- Application Container
appcon={}
appcon.activate = false
-- Tcp Port to connect to appmon_daemon.
-- No need to use this config value if using appmon_daemon default port (4242)
--appcon.port = 4243
--appcon.envvars = {}
-- @LUA_AF_RO_PATH@ is a pattern which is replaced by the runtime path LUA_AF_RO_PATH
-- when the appcon component is loaded.
--appcon.envvars.PYTHONPATH = "@LUA_AF_RO_PATH@/python"
--appcon.envvars.CLASSPATH = "@LUA_AF_RO_PATH@/java"
-- Device Management Application/Commands
device = {}
device.activate = true
--device.tcprconnect = {addr = '10.41.51.50', port = 2065}
-- Monitoring system
monitoring = {}
monitoring.activate = true
-- Lua RPC server
rpc = {}
--rpc.port = 1999
rpc.activate = true
rpc.address = '*'
data = { }
data.activate = true
data.policy = { }
data.policy.default = { latency = 5, onboot=30 }
data.policy.hourly = { latency = 60*60 }
data.policy.daily = { latency = 24*60*60 }
data.policy.never = { 'manual' }
data.policy.now = { latency = 5, onboot=30 }
data.policy.on_boot = { onboot=30 }
return config
Any ideas to what I can try?
Nicholai
