debugging code in M2M Studio
Does debugger work in current M2Mstudio or should we use an older version for the same.
I am using the debug option in RTE mode.
I experienced couple of problems.
  1. After pressing the debug button, i don’t know whether application has started running or not.how to identify?
  2. I set a break point and found that the IDE never tells whether the code has reached there or not.
  3. What is the purpose of remote task monitor window that opens after clicking debug button?
Is there any specific document that explains the process to debug the code.
I cannot answer your questions, but all those points (and a lot more) are exactly the reason why i gave up on their new unfinished dev. studio and switched back to something that just works: Visual Studio.
