Dail-up and SSL
I’m using a sl6087 modem and would like to find out if it is possible to make a dial-up connection with my PC OS and would also like to make an ssl connection with the application at the same time. I have manged to get each of these working separately but not together.
Tinus
I think it is possible to create a dial-up and ssl connection in the same application. you may have
to create separate PDP context for each.
Thank you for your reply, I got the problem fixed.
So, for the benefit of others who may have the same (or similar) question, would you care to share how you fixed the problem…?
