crash when download application
hi, i’ve download an example application to my Fasttrack Supreme, i did it several times and it is ok. But yesterday, when i download an other, it become like crash.
when i connect to FastTrack Supreme from M2m Studio, from RemoteShell Terminal, it’s keep printing this:
+WIND: 0
+WIND: 12,0
+WIND: 14
+WIND: 0
+WIND: 12,0
+WIND: 14
+WIND: 0
+WIND: 12,0
+WIND: 14
any command will not response, so i can’t remove the application, is there any way to reset my modem? thanks.
Hiya,
Sounds like you might have downloaded an application built for a different version of firmware. Probably the most reliable (but not the most straight-forward way) is to use DWLWin to erase the application.
You will need to make an appropriate cable to do this - here’s a couple of threads about making the cable, and using DWLWin to reprogram the modem (mostly to update the firmware, but you can use DWLWin to simply erase the application).
viewtopic.php?f=53&t=1907&p=11665
viewtopic.php?f=53&t=3093
ciao, Dave
hi davidc, i’m follow the link from these thread to download DWLWin but it’s seem the link was died, (i’ve logged in), and i cannot find it from wavecom website.
thanks for help.
ok, i’ve found it, thanks.
