you also need this:
at!band=9
AT!reset
you also need this:
at!band=9
AT!reset
AT!band=9,1,“groupo”,1, 0000000000000000,0000000000000004
results in ERROR
how about
AT!band=13,1,“groupo”,1, 0000000000000004,0000000000000000
yes that worked - isnt that setting the GSM mask tho?
did you check AT command user guide?
I think I see… the 1 after groupo means those masks are for LTE?
yeah - i got it now ![]()
AT!band?
Index, Name
13, groupo,
0 - GW: 0000000000000000
1 - LTE: 0000000000000004 0000000000000000
3 - NRNSA: 0000000000000000 0000000000000000
4 - NRSA: 0000000000000000 0000000000000000
AT!LTEINFO?
!LTEINFO: Unavailable
how about AT!GSTATUS? now?
Did you set the APN correctly in AT+CGDCONT?
No I forgot to set APN, I usually do it via a drone program not with AT commands. Looks like the syntax is
AT+cgdcont=1,“IP”,“lte”
AT+cgdcont?
+CGDCONT: 1,“IP”,“lte”,“0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,“”,0
AT!gstatus?
!GSTATUS:
Current Time: 563 Temperature: 45
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: No band LTE bw: 1.4 MHz
LTE Rx chan: — LTE Tx chan: —
EMM state: — —
RRC state: —
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
PCC Rx0 RSSI: — PCC Rx0 RSRP: —
PCC Rx1 RSSI: — PCC Rx1 RSRP: —
PCC Rx2 RSSI: — PCC Rx2 RSRP: —
PCC Rx3 RSSI: — PCC Rx3 RSRP: —
PCC Tx Power: — TAC: —
RSRQ (dB): — Cell ID: —
SINR (dB): 0
NR5G band: — NR5G bw: —
NR5G Tx Power: — NR5G Tx chan: —
NR5G Rx chan: — NR5G RSRP (dBm): —
NR5G RSRQ (dB): — NR5G SINR (dB): —
it says there is no such band
what does that mean? The network doesnt exist on that band? I have extensive diagnostic info about the network if that will help you
I dont see “no band” in the documentation for !lteinfo
i have no idea then, you need to find distributor for help
my phone says “LTE FDD 1800 band 3”, does that help you?
I get this now too
AT+COPS=?
+CME ERROR: operation not allowed
I think distributor can help you
distributor of what? the network?
distributor of EM9291 module
do you know what is causing the +CME error?
Do you see this error when setting at!band=0?
