voxl2:/$ echo -ne 'ATi3\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
ATi3
Model: EM9291
Revision: SWIX65C_02.13.08.00 505383 jenkins 2023/09/20 16:15:21
IMEI: 358186652129961
IMEI SV: 1
FSN: 833415552804B1
+GCAP: +CGSM
voxl2:/$ echo -ne 'AT!ENTERCND="A710"\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT!ENTERCND="A710"
voxl2:/$ echo -ne 'AT!IMPREF?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT!IMPREF?
!IMPREF:
preferred fw version: 02.13.08.00
preferred config name: GENERIC_030.047_000
preferred subpri index: 000
current fw version: 02.13.08.00
current carrier name: GENERIC
current config name: GENERIC_030.047_000
current subpri index: 000
voxl2:/$ echo -ne 'AT!GSTATUS?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT!GSTATUS?
!GSTATUS:
Current Time: 4337 Temperature: 35
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
System mode: NR5G PS state: Not attached
MM5G state: Deregistered No Cell
RRC state: RRC Idle
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
NR5G TAC: 57fe00 NR5G Cell ID: 143FCB12D (5435601197)
NR5G band: n41 NR5G Carrier ID: 0
NR5G dl bw: 100 MHz NR5G ul bw: 100 MHz
NR5G Tx Power: --- NR5G Tx chan: 0
NR5G Rx chan: 520008
NR5G dl MIMO: 4 NR5G ul MIMO: 1
NR5G(sub6) Rx0 RSSI (dBm): -64.9 NR5G(sub6) Rx1 RSSI (dBm): -67.6
NR5G(sub6) Rx2 RSSI (dBm): --- NR5G(sub6) Rx3 RSSI (dBm): ---
NR5G RSRP (dBm): -97 NR5G RSRQ (dB): -13
NR5G SINR (dB): 0.5
voxl2:/$ echo -ne 'AT+COPS?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT+COPS?
ERROR
voxl2:/$ echo -ne 'AT+COPS=?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT+COPS=?
ERROR
voxl2:/$ echo -ne 'AT!selrat?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT!selrat?
!SELRAT: 00, Automatic
voxl2:/$ echo -ne 'AT!band?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
AT!band?
Index, Name
00, All bands,
0 - GW: 100200000EC00000
1 - LTE: 0000A7E2BB0F38DF 0000000000000042
3 - NRNSA: 000081A03B0A38D7 0000000000007C62
4 - NRSA: 000081A03B0A38D7 0000000000007C62
perhaps cops is returning errors because there is no SIM inserted right now. I will put a SIM in and try again
Seems ati3 suddenly works in your side
I was sending it wrong with the echo statement. still figuring out the formatting - new to linux
Here my test shows that a SIM card must be inserted to module for entering AT+COPS=?
at+cops?
+cops: 0,0,"CMHK",7
at+cops=?
+cops: (1,"China Mobile HK","CMHK","45412",12),(2,"CMHK","CMHK","45412",7),(1,"SmarTone HK","SMC HK","45406",2),(1,"CSL","CSL","45400",12),(1,"CSL","CSL","45419",2),(1,"CSL","CSL","45400",7),(1,"454 21","454 21","45421",7),(1,"3","3","45403",2),(1,"SmarTone HK","SMC HK","45406",7),(1,"China Mobile HK","CMHK","45413",2),(1,"CSL","CSL","45400",2),(1,"3","3","45403",7),(1,"SmarTone HK","SMC HK","45406",12),,(0,1,2,3,4),(0,1,2)
at+cpin?
+CPIN: READY
ati3
Model: EM9291
Revision: SWIX65C_02.15.08.00 c5a441 jenkins 2024/01/25 19:32:58
IMEI: 358186652112345
IMEI SV: 3
FSN: 83403270212345
+GCAP: +CGSM
here are the results of the remaining commands you asked for
voxl2:/$ echo -ne 'AT+COPS?\r\n' | busybox microcom -t 5000 /dev/ttyUSB0
AT+COPS?
+COPS: 0,0,"teal",7
voxl2:/$ echo -ne 'AT+COPS=?\r\n' | busybox microcom /dev/ttyUSB0
AT+COPS=?
+COPS: (1,"T-Mobile","T-Mobile","310260",12),(2,"teal","teal","310260",7),(1,"313 100","313 100","313100",7),(1,"313 340","313 340","313340",12),(1,"Verizon","Verizon","311480",7),(1,"T-Mobile","T-Mobile","311490",12),,(0,1,2,3,4),(0,1,2)
I am not near my test network. I will go there thursday and perform the AT COPS cmd again.
It is a band 3 network which I know my modem supports. Its PLMN is 00101. I will double check these Thursday however. The sim I have in now is not my private SIM btw. I can show you those results instead later on Thursday.
I +copn and see that my PLMN (00101) is in the list. Worried cops won’t return my network on Thursday…
@jyijyi I will be at my test network in about 2 hours. I will send the output of cops? to you then
my network does not show
AT+COPS=?
+COPS: {3,"313 100","313 100","313100",7),(3,"AT&T","AT&T","310410",7),,(0,1,2,3,4),(0,1,2)
how can you confirm there is real private network there?
I can plug the SIM card into a cell phone and connect to the network. I can use a tool on the phone that confirms it is band 3
Do you have the cell id of your LTE network?
You can have a look on AT!LTEINFO? to see if it can see the neighbor cell
Yes I have the Cell id of the network. it is 518401
you can check “AT!LTEINFO?” and see if it can see this cell ID
I dont see it
AT!LTEINFO?
!LTEINFO:
Serving: EARFCN MCC MNC TAC CID Bd D U SNR PCI RSRQ RSRP RSSI RXLV
900 310 410 3339 0C350809 2 5 5 8 386 -10.5 -107.4 -76.5 22
IntraFreq: PCI RSRQ RSRP RSSI RXLV
InterFreq: EARFCN ThresholdLow ThresholdHi Priority PCI RSRQ RSRP RSSI RXLV
CA SCell : EARFCN SCID Bd ST D U Mdl Mul PCI RSRP RSSI SINR
WCDMA: UARFCN ThreshL ThreshH Prio PSC RSCP ECN0 RXLV
it is not using band 3, so it cannot see other cell id in band 3
did you limit the band to band 3 in AT!BAND?
I dont think so? Should be all bands yeah?
AT!BAND?
Index, Name
00, All bands,
AT!selrat?
if you set to all band, it will use other band
in your case, now it is using band 2
Okay - trying to piece together the AT!band command to restrict it to B3
you can see here as an example to set LTE all bands and 5G n78 only:
would this be right?
I dont care about GSM and I just want band3 LTE
AT!band=9,1,“groupo”,1, 0000000000000000,0000000000000004
AT!reset
