If I set my EM9293 on factory test mode, would I be able to connect to the internet on it?
I want to know because the AT!DARCONFIG command would allow me to set a channel number but only if I’m in factory test mode. My goal is to browse the internet on different channels in LTE bands, as part of my test.
I can’t seem to find “Get Cell lock Config” or “Set or Clear Cell Config” in the lite-qmi-nas README. Do you know where I can find that info? That’d be ideal if I can do that.
Tried the binary of lite-qmi-nas. As soon as I executed it, my lte signal freezes and the blue LED on my usb adapter stays on (doesn’t flash like it’s supposed to when connected). So, even though there was an option to “get the cell lock config” and to “set or clear cell config”, it returns an error.
Is there a reason I can’t run lite-qmi-nas while connected to LTE? Also, is there a latest modem that will support the AT!celllock for 3g/4g/5g? The MC7304 from the linked post doesn’t support those.
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R44_ENG5-lite.bin/SampleApps/lite-qmi-nas$ sudo ./bin/lite-qmi-nashostx86_64
[sudo] password for owner:
lite-qmi-nas v1.0.2505.0
Open transport "/dev/cdc-wdm0" on USB device in MBIM mode
Please select one of the following options or press 'q' to exit:
1. Set System Selection Preference
2. Set Band Preference
3. Indication Register
4. Get Signal Info
5. Get System Info
6. Set 5G Signal Strength Thresholds
7. Get Plmn Name
8. Get Cell Location Info
9. Get Network Time
10. Get LTE SIB16 Network Time
11. Get TxRx Info Ext
12. Get eDRX Params
13. Get eDRX Params Ext
14. Set eDRX Params
15. Get RF Info
16. Get System Selection Preference
17. Block Nr5g Plmn
18. Unblock Nr5g Plmn
19. Reset Nr5g Plmn Blocking
20. Set ENDC Configuration
21. Get Antenna Signal Info
22. Get Nr5g Cell Info
23. Set NR5G Band Priority
24. Get Sys Info Ext
25. Get RFDEV status (SWINAS)
26. Set mmWave config (SWINAS)
27. Get System Selection Preference Ext
28. Get CQI
29. Get Lte Carrier Cell Information
30. Get LTE CPHY Carrier aggregation Information
31. Get Modem Status Information
32. Get Home Network Information
33. Get Serving System Information
34. Get the ENDC Configuration
35. Get LTE Secondary carrier Rx signal level information
36. Set the operation of the Antenna/Receiver chain, either enabled or disabled.
37. Query the status of the Antenna/Receiver chains, either enabled or disabled.
38. Instruct the UE to perform LTE RSSI measurements on the selected Antenna.
39. Get LTE CQI
40. Get Cell lock Config
41. Set or Clear Cell Config
42. Get NR5G TX Power Info
43. Get HST Info
44. Set CMW Config
45. Get CMW Config
(q)uit to exit:
<< receiving NAS indication: NAS_SERVING_SYSTEM_IND
msgid 0x24, type:4
unpack_nas_ServingSystem_ind ret: 0 Mask: 0x40020002
Serving System Ind:
Serving system information
Registration State: QMI_NAS_REGISTERED
CS Attach State: Attached
PS Attach State: Attached
Selected Network: Detached
Radio Interface Count: 1
Radio Interface[0]: LTE
Data services capability
dataCapabilitiesLen: 1
Data Capability[0]: 11
3GPP Cell ID:25733519
40
Executing command 40 (NAS): GetCellLockConfig
GetCellLockConfig ret: 0 Mask: 0x00010004
0 element(s) in Cell List
at!gstatus?
!GSTATUS:
Current Time: 97 Temperature: 27
Reset Counter: 1 Mode: ONLINE
LTE band: B28 LTE bw: 10 MHz
LTE Rx chan: 9510 LTE Tx chan: 27510
RRC state: RRC Connected
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
PCC Rx0 RSSI: -44.6 PCC Rx0 RSRP: -71.9
PCC Rx1 RSSI: -99.7 PCC Rx1 RSRP: -131.0
PCC Tx Power: 3.0 TAC: 9f62 (40802)
RSRQ (dB): -10.8 Cell ID: 0188A9B7 (25733559)
SINR (dB): 4.4
NR5G band: --- NR5G bw: ---
NR5G Tx Power: --- NR5G Tx chan: ---
NR5G Rx chan: --- NR5G RSRP (dBm): ---
NR5G RSRQ (dB): --- NR5G SINR (dB): ---
at+Cgpaddr=1
+CGPADDR: 1,"10.9.214.67"
at!lteinfo?
!LTEINFO:
Serving: EARFCN MCC MNC TAC CID Bd D U SNR PCI RSRQ RSRP RSSI RXLV
38852 454 21 40802 0188A98F 40 5 5 4 319 -9.8 -84.4 -54.7 39
IntraFreq: PCI RSRQ RSRP RSSI RXLV
InterFreq: EARFCN ThresholdLow ThresholdHi Priority PCI RSRQ RSRP RSSI RXLV
39050 10 24 7 319 -10.9 -86.3 -67.7 37
CA SCell : EARFCN SCID Bd ST D U Mdl Mul PCI RSRP RSSI SINR
WCDMA: UARFCN ThreshL ThreshH Prio PSC RSCP ECN0 RXLV
ati3
Model: EM9291
Revision: SWIX65C_02.17.08.00 944ad5 jenkins 2024/08/01 20:22:05
IMEI: 358186652112345
IMEI SV: 5
FSN: 83403270212345
+GCAP: +CGSM
at!impref?
!IMPREF:
preferred fw version: 02.17.08.00
preferred config name: GENERIC_030.081_001
preferred subpri index: 000
current fw version: 02.17.08.00
current carrier name: GENERIC
current config name: GENERIC_030.081_001
current subpri index: 000
I get this too. After some time, it says Transport callback is invoked, type:1, value: 11. Also, what does it mean if “0 element(s) are in Cell List”; does it mean I can’t select one then?
Thanks! So for my raspberry pi, I had to run the lite-qmi-nasarm binary for it to work (not nasrpi). Also, for it to connect to internet again (and LED to flash properly), I have to re-plug the usb adapter for the modem.
BTW, when I try to clear the cell locking list by pressing enter key in option “41”, It says SetCellConfig errorCode: 1090 - Incompatible State. How can I clear the list?
Is there a way I can avoid having to restart my modem to browse the internet after locking to a cell? I have tried AT+CGATT=1 and AT+CGACT=1,1 and AT+CGDCONT but none of them allow me to browse the internet. I checked AT!GSTATUS and everything looks fine (PS state is attached, EMM state is registered)
Only a full restart using AT+CFUN=1,1 or AT!RESET fixes it but I want to avoid that since it takes time.
