CGAUTH on HL7900
I type AT+CGAUTH in hl7900 and it return
at+cgauth?
+CGAUTH: 1,0,
what 0 mean , i don’t see value 0 of CGAUTH anywhere
There is no such command in the AT command user guide …
you can see it in at command reference revision 4
Also you type it directly in evb
there is typing mistake in the AT command user guide rev 4
It should be like this:
 <auth_prot> Numeric parameter which specifies authentication protocol used for this PDP context
 0 --- None. Used to indicate that no authentication protocol is used for this PDP context.
       Username and password are removed if previously specified. (default if omitted)
 1 --- PAP
 2 --- CHAP
This will be corrected in the next version of AT command user guide
