I am considering purchase of a pre-owned gx440, I have only recently begun using these products.
I need to use Verizon, and the vendor of the pre-owned unit tells me the gx440 in question is “at&t/verizon” since they’re both LTE networks. Is it simply a matter of which carrier’s SIM you put in and activate? I am thinking I should also I expect to install the 4.3.6 firmware package for Verizon, if I find it a) has an old firmware or b) if it is programmed with an at&t specific firmware. Either way, I would plan to follow the firmware upgrade path indicated in “Application Note: Updating from Older Version of ALEOS".
Any insight or recommendations? Thanks.
