I’m trying to use SPI1 on a Q2686; R7.2a; Open-AT v6.11.
To hold the pins in a known state before starting to use them as an SPI bus, I subscribe them as “ordinary” GPIOs.
When I’m ready to use them as an SPI bus, I unsubscribe the GPIO handle before making the adl_busSubscribe call.
The GPIO unsubscribe returns OK, but the adl_busSubscribe call fails with ADL_RET_ERR_BAD_HDL (-7); which means, “a GPIO required by the bus is currently subscribed”:
But I just unsubscribed them all! ![]()
Doing an adl_ioGetCapabilitiesList confirms that none of the GPIOs associated with either SPI bus is in use:
7811.866 Trace ADL 5 pIo_defs[ 0]=00603023: Num=35 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 1]=00603022: Num=34 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 2]=00603021: Num=33 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 3]=00603020: Num=32 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 4]=0060301F: Num=31 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 5]=0060301E: Num=30 Type=3 Dir=0 Stat=0
7811.866 Trace ADL 5 pIo_defs[ 6]=0060301D: Num=29 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[ 7]=0060301C: Num=28 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[ 8]=0060301B: Num=27 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[ 9]=0060301A: Num=26 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[10]=00603019: Num=25 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[11]=00603018: Num=24 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[12]=00603017: Num=23 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[13]=00603016: Num=22 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[14]=00603015: Num=21 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[15]=00603014: Num=20 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[16]=00603013: Num=19 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[17]=0060300D: Num=13 Type=3 Dir=0 Stat=0
7811.951 Trace ADL 5 pIo_defs[18]=0060300C: Num=12 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[19]=0060300B: Num=11 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[20]=0060300A: Num=10 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[21]=00603009: Num= 9 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[22]=00603008: Num= 8 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[23]=00603007: Num= 7 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[24]=00683006: Num= 6 Type=3 Dir=0 Stat=1
7812.036 Trace ADL 5 pIo_defs[25]=00603005: Num= 5 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[26]=00603004: Num= 4 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[27]=00603003: Num= 3 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[28]=00603002: Num= 2 Type=3 Dir=0 Stat=0
7812.036 Trace ADL 5 pIo_defs[29]=00603001: Num= 1 Type=3 Dir=0 Stat=0
7812.131 Trace ADL 5 pIo_defs[30]=00603000: Num= 0 Type=3 Dir=0 Stat=0
7812.131 Trace IOB 1 bsp_spi_OpenAll: ERROR! some SPI lines are not available
7812.131 Trace ADL 5 SPI Subs: -7
