SPI Read
I am working with Q2687RD with firmware 7.47.
I need to read data from spi but adl_busRead always read 0, also if i connect the SPI1-I to 2,8V supply
I have already tested the SPI1-I GPIO28 as gpio and i can read the pin status 0 or 1.
The code is as follow
/*  File       : new_project.c                                             */
/*  Object     : Customer application                                      */
/*  contents   : Customer main procedures                                  */
#include "wm_types.h"
#include "adl_str.h"
#include "adl_port.h"
#include "adl_traces.h"
#include "adl_AppliInit.h"
#include "adl_global.h"
#include "adl_sms.h"
#include "adl_RspHandler.h"
#include "adl_TimerHandler.h"
#include "adl_gpio.h"
#include "adl_bus.h"
// Application tasks prototypes
extern void main_task ( void );
void SpiCommInit(void);
void SpiTxInit(u8 txBytes,u8 rxBytes);
void comm_TimerHandler ( u8 ID, void * Context );
void SlaveSelect(bool select);
// Definizioni
#define READ_SIZE       		4
// Handshake GPIO
#define SLAVE_SELECT			19
#define SLAVE_READY				24 //ex 31
#define GPIO_SPI_COUNT			2
#define SPI_INTERFACE			1
#define RX_BUFFER_SIZE			100
// Variabili
// SPI subscription data
adl_busSPISettings_t SpiConfig =
		127,                             // 13/(1+n) per n=0->127 100KHz
//		12,                             // 13/(1+n) per n=0->127 1MHZ
		ADL_BUS_SPI_CLK_MODE_0,
		ADL_BUS_SPI_ADDR_CS_NONE,
		ADL_BUS_SPI_CS_POL_LOW,
		ADL_BUS_SPI_MSB_FIRST,
		ADL_BUS_SPI_LOAD_UNUSED,
		ADL_BUS_SPI_DATA_UNIDIR,
		ADL_BUS_SPI_MASTER_MODE,
		ADL_BUS_SPI_BUSY_UNUSED
s32 spiHandle;
s32 gpioHandle;
adl_busAccess_t accessConfig={0,0};
adl_ioDefs_t gpioReadyConfig[GPIO_SPI_COUNT]={
		ADL_IO_GPIO|SLAVE_SELECT|ADL_IO_DIR_OUT|ADL_IO_LEV_HIGH,
		ADL_IO_GPIO|SLAVE_READY|ADL_IO_DIR_IN
u8 rxBuffer[RX_BUFFER_SIZE];
u8 rxCounter=0;
u8 rxLen;
#ifndef __GNU_GCC__
/*  Macro   : DECLARE_CALL_STACK                                             */
/*  Object  : The GCC compiler and GNU Newlib (standard C library)           */
/*            implementation require more stack size than ARM compilers. If  */
/*            the GCC compiler is used, the Open AT® application has to be   */
/*            declared with greater stack sizes.                             */
/*  Variable Name     |IN |OUT|GLB|  Utilization                             */
/*  X                 | X |   |   |  required stack size                     */
#define DECLARE_CALL_STACK(X)   (X)
#else /* #ifndef __GNU_GCC__ */
#define DECLARE_CALL_STACK(X)   (X*3)
#endif /* #ifndef __GNU_GCC__ */
// Application tasks declaration table
const adl_InitTasks_t adl_InitTasks [] =
    { main_task,  DECLARE_CALL_STACK ( 1024 ), "main", 2 },
    { 0,0,0 }
/*  Function   : main_task                                                   */
/*  Object     : Customer application initialization                         */
	adl_InitType_e InitType = adl_InitGetType ();
	SpiCommInit();
    adl_tmrSubscribe ( TRUE, 10, ADL_TMR_TYPE_100MS, comm_TimerHandler );
	wm_memset(rxBuffer,0xAA,RX_BUFFER_SIZE);
	SpiTxInit(3);
// Funzioni
void SpiTxInit(u8 rxBytes)
	rxCounter=0;
	rxLen=rxBytes;
	SlaveSelect(true);
	do
		adl_busRead(spiHandle,&accessConfig,1,&rxBuffer[rxCounter]);
		TRACE((2,"RxCounter: %d - Rx: 0x%X - Handle: %d", rxCounter,rxBuffer[rxCounter],spiHandle));
		rxCounter++;
	while(rxCounter<rxLen);
	SlaveSelect(false);
	s32 label=ADL_IO_GPIO |SLAVE_SELECT;
	adl_ioWriteSingle(gpioHandle,&label,!select);
	u32 addSize=0;
	spiHandle=adl_busSubscribe(ADL_BUS_ID_SPI,SPI_INTERFACE,&SpiConfig);
	adl_busIOCtl(spiHandle,ADL_BUS_CMD_SET_ADD_SIZE,&addSize);
	gpioHandle=adl_ioSubscribe(GPIO_SPI_COUNT,gpioReadyConfig,0,0,0);
I have added
ADL_IO_GPIO|19
to adl_busSPISettings_t struct and the spi rx start to go fine.
Wy if i have specified
