It’s not possible to connect to a Fastrack GO USB device with expresso. The first step in the connection process goes ok, but for some reason this is not the case for the second step! I get the message ‘You tried to communicate with your target, but you are not connected. Adjust your connection’s settings and hit the “Connect” button.’! I tried all different baud rates and still it doesn’t connect to the device!
In the release notes I see that there’s a known issue with the Fastrack GO USB. Is this the ‘known issue’? If so, any update on when this is going to be solved?
Thanks for the answer, but I was wondering if there will be a testversion of the firmware available before mid December to try out? I reall need the Fastrack GO USB working in the next couple of weeks and with the current firmware version is this impossible.
I can connect to the GO with hyper terminal (at least it looks like it, I can choose the right COM port with the appropriate settings) and it actually says ‘Connected’, but if I send the ‘AT’ command I don’t get the response ‘OK’.
