I am trying to get a sample application running on a Q2686H using Open AT 4.00. I’ve followed the Open AT Tutorial for Hello World and I can get the application to compile, but I cannot get it to run. Everything works as advertised in the tutorial up to the point where I click “Start” in RemoteTasks Monitor. I simply do not get any traces in the Target Monitoring Tool and no communication in the Terminal Emulator. The settings are configured correctly.
What am I doing wrong?
As a sanity check I disconnected all of the cables and tried running the application. When I clicked “Start” in RemoteTasks Monitor the status lights still went to “running,” even though I know that this is completely impossible.
MORE DETAILS
Open-AT SDK Version: 4.00
Open-AT Version: B60d09gg.Q2686H 2034956 102605 13:37
Tutorial: WM_ASW_OAT_UGD_001-006
Thanks for your help.
James
I think this particular version had a bug that prevented you from upgrading even by the use of DWLWin… Well, not too bad - considering that this version was only ‘Beta’…
