I’d like get output from cm command in an application launched on boot but I get nothing.
I use the following code:
do {
sleep(10);
/* Open the command for reading. */
fp = popen("cm info fsn", "r");
if (fp == NULL) {
syslog(LOG_ERR,"Failed to run command\n" );
exit(-1);
fgets(result, sizeof(result), fp);
trimmed = trim(result);
syslog(LOG_NOTICE,"cm info fsn result %s\n", trimmed);
/* close */
pclose(fp);
} while ((strstr(trimmed, "LL") == NULL) && (check++ < 5));
And so, I didn’t get anything in result.
Here I try with cm info fsn but the problem is the same for any other cm command in fact.
But if I replace cm info fsn by date , I do read the output of date.
I have this problem only if the application is started from the init script and even if the cm command is invoked long time after boot up.
If I start the aplication manually from bash, it’s OK.
Any idea?
