I wanted to use cm info fsn, or cm data info in init.d files but I get the following error:
root: run_getty.sh: No UART mapped to CONSOLE
Is there any solution to solve this problem?
Alain
Alain
Hi Alain,
You cannot issue Legato commands prior to Legato starting up at S44.
BR,
Chris
Hello Chris,
Ok but I’m starting at S90, through rc5.d so I’m supposed to execute cm after legato starting up no?
Here is the syslog. The last lines is where I execute cm:
Alain
Any idea please?
Alain
Hi Alain,
Can you try S90 in rcS.d? Are you certain your changes are being called properly? I don’t think rc5.d is being called.
BR,
Chris
Hi Chris,
I verified how our yocto image is built:
install -d ${D}${sysconfdir}/init.d
install -d ${D}${sysconfdir}/rcS.d
install -d ${D}${sysconfdir}/rc1.d
install -d ${D}${sysconfdir}/rc2.d
install -d ${D}${sysconfdir}/rc3.d
install -d ${D}${sysconfdir}/rc4.d
install -d ${D}${sysconfdir}/rc5.d
install -m 0544 ${WORKDIR}/initscript.sh ${D}${sysconfdir}/init.d/blackbox
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rcS.d/S90blackbox
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rc1.d/K90run-script
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rc2.d/K90run-script
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rc3.d/K90run-script
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rc4.d/K90run-script
ln -sf ../init.d/blackbox ${D}${sysconfdir}/rc5.d/S90run-script
Do you agree with that?
And according to the log I provided in a previous post, cm command is performed after Legato started up.
Alain
Still blocked on that topic!
Hi Alain,
When you added your startup script, did you manually edit the filesystem on your FX30? Or, did you rebuilt your root file system, with the startup script added?
If you manually run your script, does it function properly?
BR,
Chris
I added the startup script at build time, I didn’t added it from the FX30 shell.
And if I start it manually from FX30 shell it works.
But according to the logs, I really get an error executing cm at boot time at S90 level.
running cm once the system is fully started is ok. But it’s really not convenient for my purpose.
Hi Albo,
Are you certain your cm calls are failing? I’ve been able to execute Legato commands from startup scripts without an issue.
The message “No UART mapped to CONSOLE” that you originally reported is completely unrelated to the cm calls. Is this still an issue? If so, this is caused because you haven’t configured the UART. Try: AT!MAPUART=16,1 followed by a reboot.
BR,
Chris
So here is what I tried:
To begin, this what my /etc/rcS.d/90blackbox contains:
#!/bin/sh
# update-rc.d Update the links in /etc/rc[0-9S].d/
# (c) 2003, 2004 Phil Blundell <pb@handhelds.org>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2, or (at your option)
# any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
DAEMON=/usr/sbin/blackbox_client
NAME=blackbox
DESC="Proxy Askco"
ARGS="/etc/askco.json"
test -f $DAEMON || exit 0
set -e
case "$1" in
start)
logger -s "starting $DESC: $NAME... "
sed -i "s/#SER_NUM/$(cm info fsn)/" /etc/askco.json
logger -s "sed done."
# TODO enable start at boot
/usr/sbin/start_blackbox.sh&
logger -s "done."
stop)
logger -s -n "stopping $DESC: $NAME... "
start-stop-daemon -K -x $DAEMON
logger -s "done."
status)
echo -n "blackbox "
start-stop-daemon -q -K -t -x $DAEMON
RET=$?
restart)
logger -s "restarting $DESC: $NAME... "
$0 stop
$0 start
logger -s "done."
reload)
logger -s "reloading $DESC: $NAME... "
killall -HUP $(basename ${DAEMON})
logger -s "done."
echo "Usage: $0 {start|stop|status|restart|reload}"
exit 1
esac
exit 0
if I look at the log, I can see lot of ‘kernel’ messages, followed by lot of ‘legato’ messages and mine:
2018-08-22T16:19:12.096698+00:00 (none) Legato: INFO | posDaemon[538]/swiQmi T=main | swiQmi.c StartService() 107 | qmi_client_get_service_list rc=0, numServices=2
2018-08-22T16:19:12.464774+00:00 (none) root: starting Proxy Askco: blackbox...
2018-08-22T16:19:12.553344+00:00 (none) root: sed done
2018-08-22T16:19:12.596805+00:00 (none) root: done.
2018-08-22T16:19:12.611607+00:00 (none) Legato: INFO | modemDaemon[536]/swiQmi T=main | swiQmi.c InitService() 367 | Init QMI service QMI_SERVICE_DMS (2)
2018-08-22T16:19:12.616308+00:00 (none) Legato: INFO | modemDaemon[536]/swiQmi T=main | swiQmi.c PrintServiceDetails() 343 | Service.2: library_version.6 idl_version.1 service_id.0x2 idl_minor_version.35
and in my target file sed replaces #SER_NUM by an empty string so cm returned nothing when invoked.
if I execute ‘/etc/rcS.d/S90blackbox start’, from ssh, that works perfectly.
So you are right, I don’t see any UART error message anymore so it seems that was caused by something else not related to cm.
Anyway, at level S90 something is still missing to cm.
Hi Albo,
Could you try a different Legato command? Something simple, like “app status” or just “cm”. I’m wondering if there’s perhaps a race condition with the radio module starting up, so the information like fsn or radio data can’t be read yet.
Chris
So I added the following line:
app status > /tmp/app.log
/tmp/app.log is created but empty.
Maybe these commands work but do not output anything if there are not started from shell?
