Cannot acquire IPv6 address for EM7455 module?
IPv6 is enabled on my networking stack and it works well for other networking interfaces on my device (Ethernet and WiFi).
IPv6 does not work with EM7455. I have checked with the operator, the SIM/Account is IPv6 supported/enabled.
I have enabled IPv6 in Linux and executed AT!CUSTOM=“IPV6ENABLE”,1 as well.
The cellular interface is showing Link local address, It never acquires “Scope:Global” IPv6 address.
What is the right procedure to enable IPv6 and use IPv6 address on EM7455 under Linux?
Hi @akn
Could you please share with me the log file with some commands as below?
AT!CUSTOM?
AT!IMPREF?
AT!GSTATUS?
AT+CGDCONT?
AT!SCACT?
AT+CGPADDR
AT+CGCONTRDP
It seems that the problem was due to selection of the wrong context ID. with context ID=3 it is able to acquire the IPv6 address. I am still facing problem on ping6 to any IPv6 address.
eth3 Link encap:Ethernet HWaddr 52:53:AA:56:FD:08
inet addr:100.103.33.157 Bcast:100.103.33.159 Mask:255.255.255.252
inet6 addr: 2600:1012:b152:a173:5053:aaff:fe56:fd08/64 Scope:Global
inet6 addr: fe80::5053:aaff:fe56:fd08/64 Scope:Link
UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:21 errors:0 dropped:0 overruns:0 frame:0
TX packets:46 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3210 (3.1 KiB) TX bytes:4453 (4.3 KiB)
ethtool -i eth3
driver: GobiNet
version: 22-Aug-2005
firmware-version: GobiNet Ethernet Device
bus-info: usb-bcm-ehci-1
supports-statistics: no
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
DHCPRELAYENABLE 0x01
AT!IMPREF?
!IMPREF:
preferred fw version: 02.24.05.06
preferred carrier name: VERIZON
preferred config name: VERIZON_002.034_000
current fw version: 02.24.05.06
current carrier name: VERIZON
current config name: VERIZON_002.034_000
AT!GSTATUS?
!GSTATUS:
Current Time: 536 Temperature: 35
Reset Counter: 1 Mode: ONLINE
LTE band: B4 LTE bw: 20 MHz
LTE Rx chan: 2100 LTE Tx chan: 20100
LTE CA state: NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: -70 RSRP (dBm): -100
PCC RxD RSSI: -69 RSRP (dBm): -100
Tx Power: 0 TAC: 2F02 (12034)
RSRQ (dB): -9.3 Cell ID: 054C8E20 (88903200)
SINR (dB): 11.4
AT+CGDCONT?
+CGDCONT: 1,“IP”,“”,“0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IP”,“”,“0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“vzwinternet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
AT!SCACT?
!SCACT: 1,0
!SCACT: 2,0
!SCACT: 3,1
!SCACT: 4,0
!SCACT: 5,0
!SCACT: 6,0
AT+CGPADDR
+CGPADDR: 1,0.0.0.0
+CGPADDR: 2,0.0.0.0
+CGPADDR: 3,100.103.33.157,38.0.16.18.177.82.161.115.0.0.0.21.203.11.145.1
+CGPADDR: 4,0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
+CGPADDR: 5,0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
+CGPADDR: 6,0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
AT+CGCONTRDP
+CGCONTRDP: 3,6,vzwinternet,100.103.33.157,38.0.16.18.177.82.161.115.0.0.0.21.203.11.145.1,0.255.101.0 254.128.0.0.0.0.0.0.0.0.0.21.203.11.145.64,198.224.171.135 32.1.72.136.0.101.255.0.6.46.0.13.0.0.0.0,198.224.169.135 32.1.72.136.0.100.255.0.6.32.0.13.0.0.0.0
Hi @akn
It is known issue. Sierra is aware of this issue. Please contact your distributor directly or https://www.sierrawireless.com/support/ website for technical support in this case.
Since the original question is resolved. Please help to tick “Solution” on the answer.
