My aim is to use the CDC ECM data connection to establish a data connection between a HL8548 modem and a Linux system.
I do it successfully with an IPv4 address, but I also need to do the same with an IPv6 address, and unfortunately it does not work.
Here is what I do:
I use minicom on the ACM device to run the following AT commands:
a. Context configuration: AT+CGDCONT=1,"IPV6","<APN HERE>"
b. Data activation: AT+XCEDATA=1,0
Both of the above commands returns OK; so I am able to enable the network interface with the command: ip link set eth1 up
At this point, I’m a bit lost. To get an IPv4 address, I had to run a DHCP client on the interface. But with the IPv6 address, everything looks OK:
Hi @semurel ,
Have you tried set dynamic DNS request by command
AT+XDNS=1,3 (Enable dynamic DNS request (IPv4v6))
Also, the module should be upgraded latest build which provides full supported features and fixed
Indeed, the module was not in the last version, so I have updated the firmware with the last update (RHL85xx.5.5.26.0.201912270948.x6250_5).
Unfortunately the commands above seems now broken.
When I use the AT+XCEDATA=1,0 command, I have a CME error 148 (from the manual: “Unspecified GPRS error”).
And when I try to run it a second time, I have a CME error 4 (“Operation not supported; parameter is out of range”).
Another weird thing, it seems that the context has an IP address:
AT+CGDCONT?
+CGDCONT: 1,“IPV6”,"",“42.4.206.192.2.252.106.74.0.0.0.90.219.118.33.1”,0,0
But my interface still doesnt work (it has no more IP).
I have just tested this on 5.5.26 and it works fine.
I updated the unit before I did it and what you might have an issue with is the kusbcomp setting might have been reset to 0 in the upgrade, it needs to be set to 1 to enable the ethernet interface and enumerate properly to the system.
The network is Bouygues Telecom (French provider). I think the IPv6 is avaible on their network, because I already saw an IPv6 address on my Android phone.
But as I said I have a poor level about UMTS communications so maybe I have misunderstanding something.
