We are planing to use EM7411 to develop VoLTE application, can this module be used?
And some questions need you help?
- is there an API to do AKA authentication?
- or can we use pure AT commands to do AKA authentication?
- Do the CSIM is supported in this module? I plan to use CSIM to do AKA authentication, but always received “ERROR”, if this module support this command, could you give me a example for reference, it’s better if you can provide how to implement 3GPP TS 31.102 7.1.2 .
Thanks.
Hi @bryan_liu
→ Before answering this question, could you please provide the serial number of the device you are using?
1. is there an API to do AKA authentication?
2. or can we use pure AT commands to do AKA authentication?
3. Do the CSIM is supported in this module? I plan to use CSIM to do AKA authentication, but always received “ERROR”, if this module support this command, could you give me a example for reference, it’s better if you can provide how to implement 3GPP TS 31.102 7.1.2 .
→ For these questions, EM7411 supports the AT+CSIM command. For more detail, you can refer to below:
AirPrime EM75xx and EM/MC74x1 AT Command Reference (sierrawireless.com)
