Hi, For compliance testing on a product including the BC127 module we are being asked:
What is the max-source based duty cycle for BR / EDR ?
Antenna pattern diagram is a mandatory requirement, can you provide this or the part number of the on-board antenna?
Mike.
You are going to need to push through your commercial channel (be they a distributor or if you are direct) for this information.
Hi Matt,
I have received this reply from our supplier:
These are technical questions related to the design of the module itself which I would have thought the manufacturer would have been able to answer, they’re not things that we can help with. "
All I need is the radiation pattern for the on chip antenna or the part number, please can you help?
Mike.
