With some phones, I have trouble pairing with a BC127 acting as peripheral with A2DP sink/BLE profiles activated. I tried with a Samsung Galaxy Core and a iPhone 5c, the pairing was unsuccessful. I also tried with a Samsung Galaxy S6 and it paired successfully.
If I activate the HFP profile on the BC127 (which I don’t want to activate for our application), the pairing process is successful with all phones. Once the BC127 is paired with the phone, I can connect to the BC127 even if keep only A2DP sink/BLE profiles activated.
Is there a way to make sure that the pairing process with BC127 is always successful with only A2DP sink and BLE profiles activated?
I just did it with an S8 (previously not paired) and no issues with the pairing
status
STATE CONNECTED[0] CONNECTABLE[ON] DISCOVERABLE[ON] BLE[IDLE]
SET PROFILES=0 0 1 0 0 1 0 0 0 0 0 0
write
reset
BlueCreation Copyright 2017
Melody Audio V6.1.5
Build: 1496942680
Ready
OPEN_OK 10 A2DP EC107BFCB572
ROLE_OK EC107BFCB572 S
CLOSE_OK 10 A2DP EC107BFCB572
I also tried it with an iPhone4 and it failed with the message you gave below, I suspect it is an Apple thing where it wants to connect to more profiles.
I will look into Apple Documentation, I’m not sure I will find what I’m looking for easily. I can’t keep the HFP profile activated, because I don’t want to stream a HFP call to BC127 when I stream a track on A2DP.
I am observing the same issue as alupienbedard and this prompted me to reproduce their steps outlined in a previous post.
I believe the problem relates to previous paired devices stored by the BC127.
restore
Melody Audio V6.1.5 HD
Build: 1496941831
Ready
set profiles=0 0 1 0 0 1 0 0 0 0 0 0
write
resett
Build: 1496941831
Ready
get profiles
status
At this point I attempt to pair from a device (iPad Mini). Pairing is unsuccesful!
I then queried the list command and noticed that it was still populated, I wasn’t expecting that as the first command issued was a restore.
I then did an upair to empty the list and checked for an empty list.
list
LIST 88CB8791F5C3 HFP A2DP AVRCP
LIST 001583F0A564 A2DP
LIST 00F46F3AC34C A2DP AVRCP
unpair
list
I tried the same steps again, however this time pairing was successful.
restore
Build: 1496941831
Ready
write
reset
Build: 1496941831
Ready
get profiles
status
PAIR_PENDING
PAIR_OK 88CB8791F5C3
OPEN_OK 10 A2DP 88CB8791F5C3
ROLE_OK 88CB8791F5C3 S
CLOSE_OK 10 A2DP 88CB8791F5C3
