I got an issue while trying to enable user EQ block on Melody 6.1.5.
SET MM=ON ON 0 OFF OFF OFF OFF
GET MM : MM=ON OFF 0 OFF OFF OFF OFF
It seems the user block is never activated.
Hope you can help me to resolve that.
Best regards,
Eric
Best regards,
Eric
I think you are missing an OFF on the end.
SET MM=ON ON 0 OFF OFF OFF OFF OFF
get mm
Hi @mlw
Sorry the command I sent was wrong.
I actually send correctly :
BC127 reply OK
But GET MM command still replay : MM=ON OFF 0 OFF OFF OFF OFF OFF
Please need your advice on that.
Ok I have repeated the issue on 6.1.5 but it seems to be resolved on the later 7.2 firmware (which I also tested and it worked) even though there does not seem to be an explicit change for it (might be linked to something else).
