Just updated my BC127 to Melody V7.1 HD
All working great!
Trying to use the command VREG_ROLE=1, that is mentioned in the Melody Audio 7 user guide (page 107).
The BC127 replies with ERROR 0x0012 (Command not found).
This command doesn’t appear in the list displayed by HELP too
What is wrong?
Does the command VREG_ROLE=1 work at all?
Dave
Hello Dave,
I apologize if you have already tried this, but when you say “using the command VREG_ROLE=1”, the command is actually:
SET VREG_ROLE=1
Did you mean to say this?
GET will also tell you what value the specific configuration is. (GET VREG_ROLE will respond with “VREG_ROLE=1”)
And if you want to save your configuration when you turn off/on the module, you’ll need to type:
WRITE
after you send your set command.
I hope this helps,
Steven.
Thank you so much!
It works now, I didn’t realize I need the SET and GET…
