Hello all,
I understand that the BC127 can be directly connected to a microphone and 32ohm speakers.
I wish to connect the BC127 to a wired headset, using a 4-contacts 3.5mm PL audio jack with the following pinout:
1- TIP (Right Speaker Out)
2- Ring1 (Left Speaker Out)
3- Ring 2 (Common GND for both speakers and microphone)
4- Sleeve (Microphone in)
First question - Microphone connection:
There is an example how to connect a single microphone to the module:
Is it possible to connect the microphone to both LP/LN and RP/RN inputs? (marked in red lines)
Second question - Speaker outputs:
As mentioned, the speaker connection is a single ended type (both left and right are referenced to GND)
With no use of an external audio amplifier, What is the correct way of connecting both speakers in a single ended configuration?
Is this the right way?
Hi Matt,
1- If the microphone is connected only on the left channel, will the RX module produce only the left speaker signal or both left and right? if mic LP/LN in mono mode is connected internally to RP/RN by software so yes, it is not necessary, but is it really so?
2- Ok, understood.
Thanks for your reply
Nir
So the short answer is that if you connect one mic then that will be the audio that is transmitted, whether that is stereo or not depends on the BT profile being used.
