BC127 Broadcast Audio — Initial Configuration Error 0x001A
I have two BC127. I want to use them one’s as a receiver and the other one is broadcaster.
My verison is Melody Audio V7.2.
I tried to implement Broadcost Audio from datasheet (page 176). from examples.
I have to use “SET BA_CONFIG=1 ON” like this accordıng to my BC127.
And then I realized that
BA_CONFIG Usage:
• Format (Melody 7.1):
BA_CONFIG= <enable_auto_broadcast> <broadcaster_product_id> <broadcaster_version_id>
Purpose: Broadcast Audio configuration—Set Broadcast Audio mode and (in broadcaster mode) configure broadcaster
settings.
• Format (Melody 7.2 and later):
Purpose: Broadcast Audio configuration—Set Broadcast Audio mode and enable/disable auto-broadcast.
Default: (Melody 7.1)
BA_CONFIG=0 ON 0A02 0304
(Broadcast Audio enabled, auto-broadcast enabled, product id=0A02, version id = 0304)
BA_CONFIG=0 OFF
(Broadcast Audio enabled, auto-broadcast disabled)
Reboot required: Yes
Finally, I wrote SET BA_CONFIG=1 ON because of version 7.2 , I got an error. :frowning:
SET BA_CONFIG=1 ON
ERROR 0x001A
Please Help Me?
Now, when I wrıte “RESET”, I take a message like this
For Terminate1
RESET
Sierra Wireless Copyright 2018
Melody Audio V7.2
Build: 1534785311
Ready
OPEN_OK 11 AVRCP 20FABB01FFE5
ABS_VOL 11 84
ABS_VOL 11 84
OPEN_OK 10 A2DP 20FABB01FFE5
For Terminate 2
RESET
Melody Audio V7.2
Build: 1534785311
Ready
OPEN_OK 11 AVRCP 20FABB01FFE6
ABS_VOL 11 84
ABS_VOL 11 84
OPEN_OK 1A TWS 20FABB01FFE6
@yesimkalkan,
The standard releases which are posted on the source do not support broadcast, you need a specific version which you will need to get through your distributor.
Firstly,thank you very much for your attention. :grinning: @mlw
I want to communicate two BC127s in each other. One card has a microphone the other one has a headset. Should I use Headset Profile (HSP) to transfer the audio from one the other one?
I’m sure, I connected my devıces because I’ve heard meaningless sounds like bipp during writing code via headseat. But, I couldn’t understand where my fault is.
I gave the my version and code examples at below. Thank you very much again…!!! :slight_smile:
*For Microphone part
RESET
Melody Audio V7.2
Build: 1534785311
Ready
ABS_VOL 11 84
ABS_VOL 11 84
CLOSE_OK 11 AVRCP 20FABB01FFE5
LINK_LOSS 10 1
ABS_VOL 11 84
ABS_VOL 11 84
LINK_LOSS 10 0
WRTIE
ERROR 0x0012
WRITE
VERSION
Melody Audio V7.2
Build: 1534785311
Bluetooth addresses: 20FABB01FFE6 6683A6AC1161
Profiles: A2DP AVRCP HFP BLE SPP PBAP MAP TWS
Codecs: SBC
RESET
Melody Audio V7.2
Build: 1534785311
Ready
BT_STATE ON ON
ERROR 0x0013
BT_STATE ON ON
INQUIRY
PENDING
INQU_OK
INQUIRY
PENDING
INQUIRY 20FABB01FFE5 “BC-01FFE5” 240404 -51dBm
INQUIRY 20FABB01FFE5 “BC-01FFE5” 240404 -52dBm
INQUIRY 20FABB01FFE5 “BC-01FFE5” 240404 -54dBm
INQUIRY 20FABB01FFE5 “BC-01FFE5” 240404 -50dBm
INQUIRY 20FABB01FFE5 “BC-01FFE5” 240404 -49dBm
INQU_OK
OPEN 20FABB01FFE5 HSP
ERROR 0x0013
OPEN 20FABB01FFE6 AGHFP
ERROR 0x0011
OPEN 20FABB01FFE5
ERROR 0x0013
OPEN_OK 15 SPP 20FABB01FFE5
CALL_ACTIVE 12
ERROR 0x0012
CALL_ACTIVE 13
ERROR 0x0012
CALL INCOMING 12
ERROR 0x0013
CALL 12 ACTIVE
ERROR 0x0017
CALL 12 INCOMING
ERROR 0x0017
CALL 13 INCOMING
ERROR 0x0017
CALL 12 INCOMING
ERROR 0x0017
CALL 12 OUTGOING
ERROR 0x0017
CALL 12 INCOMING “123456”
ERROR 0x0017
SET PROFILE HFP ON
ERROR 0x001A
SET BT CLASS 200404
ERROR 0x001A
RESET
Melody Audio V7.2
Build: 1534785311
Ready
SET PROFILE HFP-AG ON
ERROR 0x001A
***********For Headset Part *********
ABS_VOL 11 84
ABS_VOL 11 84
RESET
Melody Audio V7.2
Build: 1534785311
Ready
ABS_VOL 11 84
ABS_VOL 11 84
WRITE
VERSION
Melody Audio V7.2
Build: 1534785311
Bluetooth addresses: 20FABB01FFE5 6ECF2A826639
Codecs: SBC
VERSION
Melody Audio V7.2
Build: 1534785311
Codecs: SBC
RESET
Melody Audio V7.2
Build: 1534785311
Ready
INQUIRY
PENDING
INQUIRY 20FABB01FFE6 “BC-01FFE6” 240404 -47dBm
INQUIRY 20FABB01FFE6 “BC-01FFE6” 240404 -46dBm
INQUIRY 20FABB01FFE6 “BC-01FFE6” 240404 -48dBm
INQU_OK
ERROR 0x0011
BT_STATE ON ON
ERROR 0x0013
OPEN 20FABB01FFE6
ERROR 0x0013
OPEN 20FABB01FFE6 SPP
PENDING
OPEN_OK 15 SPP 20FABB01FFE6
CALL_ACTIVE 12
ERROR 0x0012
CALL_ACTIVE 13
ERROR 0x0012
CALL_INCOMING 12
ERROR 0x0012
CALL 13 ACTIVE
ERROR 0x0017
CALL 12 INCOMING
ERROR 0x0017
CALL 13 INCOMING
ERROR 0x0017
CALL 13 ANSWER
ERROR 0x0017
CALL 13 REDIAL
ERROR 0x0017
SET PROFILE HFP ON
ERROR 0x001A
SET BT CLASS 200404
ERROR 0x001A
RESET
Melody Audio V7.2
Build: 1534785311
Ready
ERROR 0x001A
@yesimkalkan,
So you want to set up unidirectional audio or bi directional? If its uni directional then I would suggest using A2DP as this will open up the audio interfaces. If it is bi directional then you will have an issue as the HFP/HSP are designed around interfacing to a phone which handles call control, you cannot place a ‘call’ between two BT modules and have bi directional audio like a private radio.
Dear @mlw
Thanks for the interest you have shown.:pray: My communication type is bidirectional. For this reason, I have to use HFP profile, I understood this thanks to you. Thank you again.:raised_hands::grinning: I tryied to below codes but I got an error during connection request. I thought that my profıle must be “2 0 0 0 0 0 0 0 0 0 0 0” or “1 1 0 0 0 0 0 0 0 0 0 0”. Maybe my error is here or not?
***** Mıcrophone Side ******
RESET
Melody Audio V7.2
Build: 1534785311
Ready
VERSION
Melody Audio V7.2
Build: 1534785311
Bluetooth addresses: 20FABB0789A0 000000000000
Profiles: A2DP AVRCP TWS
Codecs: SBC
BT_STATE ON ON
INQUIRY
PENDING
INQUIRY 20FABB07899B “BC127_MODULE2” 240404 -43dBm
INQUIRY 20FABB07899B “BC127_MODULE2” 240404 -45dBm
INQUIRY 20FABB07899B “BC127_MODULE2” 240404 -44dBm
INQUIRY 20FABB07899B “BC127_MODULE2” 240404 -42dBm
INQU_OK
LIST
LIST 20FABB01FFE5 AVRCP TWS
GET AUDIO
AUDIO=0 0
GET BT_VOL_CONFIG
BT_VOL_CONFIG=A 60 10 1
GET BALANCE
BALANCE=100 100
GET DEVICE_ID
GET HFP_CONFIG
HFP_CONFIG=OFF ON OFF OFF OFF OFF
SET PROFILES=2 0 0 0 0 0 0 0 0 0 0 0
GET PROFILES
WRITE
OPEN 20FABB07899B HFP
PENDING
OPEN_ERROR HFP
RESET
Melody Audio V7.2
Build: 1534785311
Ready
PENDING
OPEN_ERROR HFP
SET PROFILES=1 0 0 0 0 0 0 0 0 0 0 0
PENDING
OPEN_ERROR HFP
SET PROFILES=1 1 0 0 0 0 0 0 0 0 0 0
PENDING
OPEN_ERROR HFP
OPEN 20FABB07899B AGHFP
ERROR 0x0011
ROUTE
ROUTE 0
ROUTE 23
ERROR 0x0011
ROUTE 21
ERROR 0x0011
***** Headset Side ******
RESET
Melody Audio V7.2
Build: 1534785311
Ready
VERSION
Melody Audio V7.2
Build: 1534785311
Bluetooth addresses: 20FABB07899B 000000000000
Codecs: SBC
INQUIRY
PENDING
BT_STATE ON ON
INQU_OK
INQUIRY
PENDING
INQUIRY 20FABB0789A0 “BC127_MODULE4” 240404 -46dBm
INQUIRY 20FABB0789A0 “BC127_MODULE4” 240404 -43dBm
INQUIRY 20FABB0789A0 “BC127_MODULE4” 240404 -44dBm
INQUIRY 20FABB0789A0 “BC127_MODULE4” 240404 -42dBm
INQU_OK
GET AUDIO
AUDIO=0 0
GET BT_VOL_CONFIG
GET BALANCE
BALANCE=100 100
GET DEVICE=ID
ERROR 0x0013
GET DEVICE_ID
GET HFP_CONFIG
GET PROFILES
GET PROFILES
WRITE
OPEN 20FABB0789A0 HFP
PENDING
OPEN_ERROR HFP
PENDING
OPEN_ERROR HFP
OPEN 20FABB0789A0 AGHFP
ERROR 0x0013
ROUTE
ROUTE 0
ROUTE 23
ERROR 0x0011
ROUTE
ROUTE 0
@yesimkalkan,
So the issue you have here is that you cannot just send some commands to the unit and have a bi directional audio link running between them, the profiles are built around working with devices that have call control on them (like phones), the BC127 does not have this capability.
Hello Matt,
I appreciate you helping to me @mlw :raised_hands: . Thank you very much again :smiley::pray:. How can I transfer audio without sending any commands during bidirectional communication? Now, I’m so confused.I couldn’t understand this. Could you explain this issue detailed, please?
Best Regards,
Yesim
@yesimkalkan,
You cannot just connect two BT units (like the BC127) with HFP/HSP together and they then open up a bi directional audio channel. The channel is only opened up when something which has call control implemented (which BT devices, generically speaking, do not have) such as a phone initiates or receives a call.
Hello @mlw
Thank you very much for your answers and help :grinning:.
If I couldn’t two bc127 modules together with HSP/HFP, I had to change profiles.
I think that one of them is AGHFP which is source of sound via microphone, the other one is HFP from that listening sound via headset. I assumed I connected them in each other. I gave my code below my message. I used ROUTE 0 (default), ROUTE and ROUTE 2 (bidirectional). But, I couldn’t hear any voice from microphone with headset. And then, I tried A2DP and HFP configuration. Unfortunately, result is unsuccessful.
So my 1st Configuration: Speak to microphone->AGHFP mode(BC127_Module1)->Bluetooth connection in eachother ->HFP mode(BC127_Module2)->Hear Sound from Headset
My 2nd Configuration: Speak to Microphone->A2DP mode (bc127_moule_1)->Bluetooth connection in eachother->HFP mode(BC_127_Module2)->Hear Sound from Headset
For A2DP and HFP Profıle was1 0 0 1 1 0 0 0 0 0 0 0. But I couldn’t hear any voice comes from microphone.
I wonder that, are all my steps right/enough or not for audio transfer?Are my configuration true or not? What do I need to do to achieve success? Could you help me, please?
Best Regards,
Yesim
***************** MICROPHONE PART ***************************
RESET
Melody Audio V7.2
Build: 1534785311
Ready
STATUS
STATE CONNECTED[0] CONNECTABLE[ON] DISCOVERABLE[OFF] BLE[OFF]
VERSION
Melody Audio V7.2
Build: 1534785311
Codecs: SBC
WRITE
RESET
Melody Audio V7.2
Build: 1534785311
Ready
GET PROFILES
BT_STATE ON ON
ERROR 0x0013
BT_STATE ON ON
ERROR 0x0013
BT_STATE ON ON
STATUS
STATE CONNECTED[0] CONNECTABLE[ON] DISCOVERABLE[ON] BLE[OFF]
PENDING
OPEN_ERROR HFP
PENDING
OPEN_OK 13 HFP 20FABB07899B
ERROR 0x0011
RESET
Melody Audio V7.2
Build: 1534785311
Ready
PENDING
ROUTE 0
ROUTE
ROUTE 0
VERSION
Melody Audio V7.2
Build: 1534785311
Profiles: AGHFP HFP
LIST
LIST 20FABB07899B HFP
LIST 8C1ABF5C4363 A2DP AVRCP
ROUTE 2
SET AUDIO_ANALOG=15 15 1 OFF
SET AUDIO=0 1
ROUTE
ROUTE 2
******************* HEADSET PART *****************
RESET
Melody Audio V7.2
Build: 1534785311
Ready
STATUS
VERSION
Melody Audio V7.2
Build: 1534785311
Codecs: SBC
WRITE
RESET
Melody Audio V7.2
Build: 1534785311
Ready
GET PROFILES
BT_STATE ON ON
ERROR 0x0013
BT_STATE ON ON
STATUS
PENDING
OPEN_ERROR AGHFP
OPEN_OK 12 AGHFP 20FABB0789A0
REMOTE_VOLUME 12 A
ERROR 0x0011
ERROR 0x0011
ERROR 0x0011
RESET
Melody Audio V7.2
Build: 1534785311
Ready
PENDING
REMOTE_VOLUME 12 A
VERSION
Melody Audio V7.2
Build: 1534785311
Profiles: AGHFP HFP
LIST
LIST 8C1ABF5C4363 A2DP AVRCP BLE
LIST 20FABB0789A0 AGHFP
LIST 149F3CA0E2D8 BLE
ROUTE 2
SET AUDIO=1 1
Dear @mlw
Could yo help me, please? I need your help.
Best Regards,
Yesim
@yesimkalkan,
Let me be clear, you cannot do what you want to do, period, you cannot create a BT link between two BC127’s and have an audio link between them with no other device (such as a phone) controlling the call.
Dear @mlw
Thank you very muh for your answer. I just wanted to use this configuration like page 8 of the link. Have a nice day. Thank you.
Best Regards,
Yesim
Link:
Mlw,
I am reading this thread with great interest. I am trying to use the audio input and output of a MOVI board (see audeme.com) to got through a BC127 and connect to a bluetooth earbud (Plantronics VT5200). From what I read in this thread, what I want to do is not possible just with those devices. Is this true?
If a cell phone is used to control the communication, can I substitute an arduino board to handle the connection? My project that the MOVI board is connected to already has an arduino board attached.
My end result I am looking for is to allow a quadriplegic person to operate a gripping device using voice control. It already works using a mic and speaker. I want to cut out the mic and speaker and go wireless to an earbud.
Do you think this is possible? Thanks very much.
Bart
