Please find the attached circuit and I wonder the status of pin No. 7,8,9,10,5,6,23,24,25,26,50,51 should be “Float” or “ Pull down or pull up”.
Pin No 38 needs to be connected to 3.3volt?
one more question please, BC127 APT-x HD provides(streaming) text to the device? like showing tags of mp3 file, name of song, singer and sampling rate and etc
For the hardware questions, could you push them to your distributor and they will get it into the system for Sierra to look at.
Re question 3 no the unit does not supply things like track number, album name, sampling rate, etc as far as I am aware, you need to implement this yourself.
for No. 3 question, what I meant was if a bluetooth device streams text information like song title, time and etc, does BC127 take care of this is? and is their any way how to provide this information to the adopted display?
there is a display on our device and I would like to have the display shows those information, album title, song title singer, remaining time and etc. How can I configure this on bc127?
Hi again,
pu
thank you very much. So the unit generate the data for song info and etc. and the remaining is our coding at our cpu and display controller level.
And it seems we need to set AVRCP function at Melody for having those data coming out of the unit, correct?
