We’ve been having issues with about 5% of our BC118s where they don’t initialize properly or start to broadcast.
We’ve noticed that by heating the units in a thermal chamber or with a hot air gun, the BC118s initialize correctly and communicate as expected. If the units are subsequently cooled, they continue to operate correctly, But a power cycle at low temperature (<0°C) will result in initialization failure and failure to broadcast.
Here is some identifying info. regarding the units that exhibit this behavior:
MAC Address Lot Code
20FABB0B5C3C 1847
20FABB0B66C8 1847
20FABB0B671B 1847
20FABB0B62EC 1847
Someone on my team has also sent in the following 2 units for RMA (W2223572) which exhibit similar behavior:
20FABB046982
20FABB0B5E3E
Is this a known issue? Or is anything pertaining to initialization extremely time/temperature dependent?
(We have ensured that the 3.3V rail reaches 1.8V in less than 1.5ms per the data sheet.)
Perhaps something is marginal in either the BC118 or our supporting circuitry.
I would like a reference design, but have not found one online.
I would suggest you go back to your channel and push to have a design review performed 0 degrees is not very cold and the units should work quite happily there and/or under it.
We test down to -40°C, and our unit meets or exceeds our spec. except for [roughly 5% of] this one peripheral, which does work unless initialized below roughly 0°C. We’ve had several design reviews and tried many topology changes, but we’re always open to new ideas/suggestions.
To that point, can you please direct me to all application info. specific to the BC118?
I currently have the document: “AirPrime BC118 Product Technical Specification” 41110676 Rev 2
I will be examining the initialization process at hot and cold temperatures more thoroughly, and will post here if I find anything significant.
Thank you in advance for directing me to the existing knowledge base.
-Kyle
All of the available technical documentation is on the source, including the PTS, which you have which I guess means you have already accessed the below page (you need to create yourself a login)?
As I say it is unusual because the PTS does state that the unit is operational down to -40 (that does generally mean that you can power it up down to this level, not that it will just stay on.
I’ve disconnected the BC118 from our MCU and repeated the same start-up test at -20°C and room temperature.
The BC118 fails to initialize when it is cold (as witnessed by its Tx pin over a 10 second period.)
Results can be seen in this online gallery: https://imgur.com/gallery/xrzyxc3
I’d like to start an RMA process for this sample. Can you help me with that?
-Kyle
Firmware in EEPROM was changed or corrupted. Module can be recovered after FW re-flash
20fabb0b5e3e
BC118
EEPROM hardware fault
In both cases, something “under the hood” of the BC118 was misbehaving.
I have to ask what we can do differently?
And is this is a known issue? (With know resolution?)
If Sierra Wireless is interested, we have several more units that exhibit behavior that is out of spec.
