I may be missing something but while reading through the specs I didn’t see any details on the pads located above the mpcie interface. Are any details available on these? Hoping they could be used to solder in sim card interfaces (might be a pipe dream).
Keith,
When you say above do you mean pads outside the system connector? If so then these are not documented as they are test pads, customers can only use the pins with the PCI connector.
