Hi
I use “at+wipcfg=1” command but it gives only ERROR in terminal. Terminal is works fine. I checked it for AT commands.
Is there any possible way to work this command?
Thanks in Advance.
Regards - Senthil.
Hi
Thanks in Advance.
Regards - Senthil.
Use AT+CMEE=1 to get a more detailed error code.
Thanks for ur reply.
I use that command (at+CMEE) also, but it doesn’t display any error values.
Is there any idea?
Regards - Senthil.
AT+CMEE=1 just enables the extended error codes - it doesn’t give any error information itself.
Once you have enabled the extended error codes, the next time a command wants to report an error, it will give the extended +CME ERROR or +CMS ERROR reply.
Note that the setting is volatile - you have to save it with AT&W if you want it to be retained over a restart…
