I am experiencing the following problem while trying to implement roaming behaviour into our WMP100 application.
It looks like at command “at+cops=?” does not give the correct response when used with adl_atCmdCreate.
Look at the following code snippet:
adl_atCmdCreate(“at+cops=?”, FALSE, COPS_Handler, "+COPS: ", NULL);
bool COPS_Handler(adl_atResponse_t *paras)
debugPrintf(uri, “%s”, paras->StrData);
I expected debugPrintf to display something like this:
+COPS: (2,“T-Mobile D”,“T-Mobile D”,“26201”),(3,“o2 - de”,“o2 - de”,“26207”),(3,“Vodafone.de”,“voda DE”,“26202”),(3,“E-Plus”,“E-Plus”,“26203”)
Instead it just displays this:
+COPS:
Note : If I run the same “at+cops=?” on the AT command line, it gives the expected output. Aso if I replace “at+cops=?” with just “at+cops?” or any other AT command in the adl_atCmdCreate call, then it also gives the correct output. It is only the command “at+cops=?” that is not giving the correct response.
Here is the fw version that we use: R71a01gg.WMP100 2076692 052808 20:08
Hope someone has some advise as this is driving me nuts!
