API to send a command to a device
I would like to modify a virtual ressource from an API.
Which API is dedicated ?
I would like to use the Event API to create an event on :command Stream, but I don’t how to get the stream Id of :command for a device.
Hi Romuald,
You can find the answers to your questions here: https://docs.octave.dev/docs/from-a-rest-api-call#temporarily-changing-a-value-via-an-event
Hi
My processus are manage by automate.
So, I need to get the :command stream Id by API not on the UI.
Hi Romuald,
This should work for you
https://octave-api.sierrawireless.io/v5.0//stream/?filter=path=="//devices/<device_name>/<stream_name>"
Example:
https://octave-api.sierrawireless.io/v5.0/iot_solutions/stream/?filter=path=="/iot_solutions/devices/fx30_jdj/:command"
