Hi people,
is there an ADL internal function for sending RAW data to the GPS ? I am looking for a function which makes the same as the command AT+WGPSRAW but with faster reaction.
Does anyone know this very detailed point ?
Thanks in advance,
Stefan Pelimon
I dont think there is an other command for that. Is AT+WGPSRAW slow?
If you would like to use the internal GPS of q2501 as a full u-blox GPS receiver, you can use it in external mode with an additional controller. Or a morbid idea, the you use the GPS in external mode through UART2 connected to the GPS serial link.
Best Regards,
tom
Hi Tomalex,
thanks for the support,
I must say yes, that AT+WGPSRAW is some kind of slow command. If you have to send a sequence of commands, you must give them “air” by using adapted timers…
At least it will force me once more to make proper coding.
Greetings,
Stefan Pelimon
