This very simple program crashes the RTE:
#include "adl_global.h"
#include "wm_snd.h"
u32 wm_apmCustomStack [ 256 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
void Cmd_TONE_Handler ( adl_atCmdPreParser_t * paras )
switch ( paras->Type )
case ADL_CMD_TYPE_TEST :
adl_atSendResponse ( ADL_AT_PORT_TYPE ( paras->Port, ADL_AT_RSP ), "\r\n+TONE: (1-3999),(1-255),(0-15)\r\n" );
adl_atSendStdResponse ( ADL_AT_PORT_TYPE ( paras->Port, ADL_AT_RSP ), ADL_STR_OK );
break;
case ADL_CMD_TYPE_PARA :
ascii *p;
s32 result;
u16 Frequency; u8 Duration; u8 Gain;
p = ADL_GET_PARAM ( paras, 0 );
Frequency = (u16)wm_atoi((void*)p);
p = ADL_GET_PARAM ( paras, 1 );
Duration = (u8)wm_atoi((void*)p);
p = ADL_GET_PARAM ( paras, 2 );
Gain = (u8)wm_atoi((void*)p);
if ( (Frequency>0) && (Frequency<4000) && (Duration>0) && (Gain<16) ) {
result = wm_sndTonePlay ( WM_SND_DEST_SPEAKER, Frequency, Duration, Gain );
if (result>=0)
else
adl_atSendResponse ( ADL_AT_PORT_TYPE ( paras->Port, ADL_AT_RSP ), "\r\n+TONE ERROR\r\n" );
} else
adl_atSendResponse ( ADL_AT_PORT_TYPE ( paras->Port, ADL_AT_RSP ), "\r\n+CME ERROR: 3\r\n" );
break;
TRACE (( 1, "Embedded : Appli Init" ));
adl_atCmdSubscribe("at+tone", Cmd_TONE_Handler, ADL_CMD_TYPE_TEST | ADL_CMD_TYPE_PARA | 0x0033 );
with this error
after I enter the last line here
+WIND: 13
+WIND: 0
+WIND: 7
+CGREG: 0
+CREG: 0
+CGREG: 0
at+tone=?
at+tone=2000,5,0
I checked with the debugger, the crash is in the line with the wm_sndTonePlay call! Everything else including the extraction of the parameters works fine.
What is going on here?
Best Regards,
Jan
