Hello together,
I planning a project for a measurement system.
We also deviced to use a Airlink GX450 with LTE/Wifi/GPS.
LTE and Wifi is working fine.
But with GPS I have problems to integrate it in our system.
I need an NMEA (GGA+VTG+RMV) Stream over Ethernet, means over TCP on Port 22.
My Computer (Datalogger Computer with Windows 8.1) is connected with a LAN Cable to the Router.
IP Computer: 192.168.13.100
IP Router: 192.168.13.31 (Webinterface over port 9191)
Now I mad several tests and sometimes the stream will be available on the pc, somethimes not.
I’m not sure which settings I need and which one could make maybe problems.
There are 3 tabs for making settings:
Gobal-Settings
Server-Settings
Stream Settings
I’m absolutly not sure which of this 3 settings I need for a Ethernet GPS Stream over TCP to Port 22 of my Computer (192.168.13.100).
Could one of you help my, please?
Thank you in advance.
Best regars
Matthias
