Why does HL8548-G cut the TCP connection after GPS is used?
I couldn’t solve this problem. Please give me any advice.
I want to execute the following things
①Open a TCP connection
AT+KTCPCLOSE=1
AT+KTCPDEL=1
AT+CGATT=0
AT+KCNXCFG=1,“GPRS”,“xxx.com”,"xx@xxx.com",“xxx”
AT+CGDCONT=4,“IP”,“xxx.com”
AT+KCNXPROFILE=1
AT+KGNSSAD=1
AT+CGATT=1
AT+KTCPCFG=1,0,“some_url”,some_port
AT+KCNXUP=1
AT+KTCPCNX=1
②Turn on GPS function and receive NEMA data
AT+GPSNMEA=01,1
AT+GPSSTART=0
[NEMA data storing process]
③Turn off the GPS function
AT+GPSSTOP
AT+GPSNMEA=01,0
④Send NEMA data on TCP connection
AT+KTCPSND=1,[word count]
[Data sending process]
In this flow, TCP connection is cut on process④
Data can be sent if I do process④ after I redo process① right before process④
Why does this happen?
How can I use GPS function without cutting TCP connection?
Hi fyusuke,
I cannot see your issue my side (I test with v5.5.24.2).
Could you kindly to show me your full AT log with the following?
ATI3
AT+CGREG?
AT+CGDCONT=4,“IP”,“xxx”
AT+KCNXCFG=1,“GPRS”,“xxx”
AT+GPSSUPLCFG=0,“suplcn.sirf.com”,7276,1,0
AT+GPSSUPLCFG?
AT+CGDCONT?
AT+KTCPCFG=1,0,“xx.xx.xx.xxx”,5045
AT+KCNXUP=1
AT+KTCPCNX=1
AT+GPSNMEA=01 //NMEA output on UART1
AT+GPSSTART=0
AT+CGDCONT?
AT+CGPADDR
AT+GPSSTOP
AT+KTCPSND=1,10
AAAAAAAAAA–EOF–Pattern–
+KTCP_DATA: 1,10
AT+KTCPRCV=1,10
AT+CGDCONT?
AT+GPSSTOP
AT+KTCPCLOSE=1,1
AT+KTCPDEL=1
AT+KCNXDOWN=1,1
Thank you for your comment.
[Environment]
・STM32L053
・use MQTT protocol
・receive return values of AT commands by interrupt
I sent the following command.
AT
AT&K3
ATE0
ATI3
AT+CGREG?
AT+CGDCONT=4,“IP”,“xxxcom”
AT+KCNXCFG=1,“GPRS”,“xxxcom”,“xxx@xxxcom”,“xxx”
AT+GPSSUPLCFG=0,“suplcn.sirf。com”,7276,1,0
AT+GPSSUPLCFG?
AT+CGDCONT?
AT+KTCPCFG=1,0,“xxxxxxxxcom”,1883
AT+KCNXUP=1
AT+KTCPCNX=1
AT+GPSNMEA=01
AT+GPSSTART=0
AT+CGDCONT?
AT+CGPADDR
AT+GPSSTOP
AT+KTCPSTAT=1
AT+KTCPSND=1,23
AAAAAAAAAA,bty=0–EOF–Pattern–
AT+KTCPSTAT=1
AT+CGDCONT?
AT+GPSSTOP
AT+KTCPCLOSE=1,1
AT+KTCPDEL=1
AT+KCNXDOWN=1,1
And I got the following result.
AT
AT
AT&K3
AT&K3
ATE0
ATE0
ATI3
RHL85xx.5.5.22.0.201603171544.x6250_3
AT+CGREG?
+CGREG: 0,1
+GPSEVINIT: 1
AT+GPSSUPLCFG?
+GPSSUPLCFG: 0,“suplcn.sirf。com”,7276,1,0
+GPSSUPLCFG: 1,-1,1,1
AT+CGDCONT?
+CGDCONT: 4,“IP”,“xxxcom”,“0.0.0.0”,0,0
+KTCPCFG: 1
AT+KCNXUP=1
+KCNX_IND: 1,4,1
AT+KTCPCNX=1
AT+GPSNMEA=01
+KCNX_IND: 1,1,0
+KTCP_IND: 1,1
AT+GPSSTART=0
AT+CGDCONT?
+CGDCONT: 1,“IP”,“xxxcom”,“100.90.200.180”,0,0
+GPSEVSTART: 1
$GPVTG…
+GPSEVPOS: 0
$GPVTG,0
AT+CGPADDR
0,T,…
$GNGNS…
+CGPADDR: 4,“100.90.200.180”
$GPVTG…
AT+GPSSTOP
.0,T,…
$GNGNS…
+GPSEVSTOP: 1
+GPSEVPOS: 0
AT+KTCPSTAT=1
+KTCPSTAT: 3,-1,0,0
AT+KTCPSND=1,23
CONNECT
End of transmission
AT+KTCPSTAT=1
CNX_IND: 1,0,0
+KTCP_NOTIF: 1,0
+KTCPSTAT: 1,0,0,0
AT+CGDCONT?
+CGDCONT: 1,“IP”,“xxxcom”,“0.0.0.0”,0,0
AT+GPSSTOP
ERROR
AT+KTCPCLOSE=1,1
ERROR
AT+KTCPDEL=1
AT+KCNXDOWN=1,1
I replaced suplcn.sirf.com with suplcn.sirf。com because new user can post only two links. I can write “.com” only two times.
Hi fyusuke,
Please check result of AT+KIPOPT? and pay attention to the following settings:
AT+KIPOPT=3,<stop_on_error>,<stop_on_peer>
Suggest to set AT+KIPOPT=3,0,0.
<stop_on_error> PDP connection deactivation behavior when a session is closed due to any error
0 Do not request to stop the connection
1 Request to stop the connection
<stop_on_peer> PDP connection deactivation behavior when a session is closed by a peer/server
Sierra_klin1
Thank you for your advice.
I checked it and result is following
AT+KIPOPT?
+KIPOPT: 0,"TCPC",1,0,0
+KIPOPT: 0,"TCPS",1,0,0
+KIPOPT: 0,"UDPC",2,1020,1020
+KIPOPT: 0,"UDPS",2,1020,1020
+KIPOPT: 0,"FTP",1,0,0
+KIPOPT: 0,"HTTP",1,0,0
+KIPOPT: 0,"HTTPS",1,0,0
+KIPOPT: 1,0
+KIPOPT: 2,0
+KIPOPT: 3,0,0
+KIPOPT: 4,0
It seems to be OK.
I checked if the server receives the data when I send data after GPS func is used, and it doesn’t. However, it does, when I skipped the GPS func at command. why…
Hi fyusuke,
I just noticed that with your SIM/Network, it seems the fixed and only ONE IP 100.90.200.180 is allocated for the PDP context #1 and #4. That’s why when the AGPS finished the connection(PDP#4), the TCP(PDP#1) is released as well.
AT+CGDCONT?
+GPSEVSTART: 1
+GPSEVPOS: 0
AT+CGPADDR
The solution could be:
1) Disable the AGPS
AT+CGDCONT=4
AT+GPSSUPLCFG=0,“suplcn.sirf.com”,7276,0,0 // as 0(SUPL disable) for URC
2) Start the TCP after AGPS.
Hi, Sierra_lin1
I see. What about the result with YOUR SIM. Is this problem caused by my SIM network, or the device itself?
Hi fyusuke,
Yes, this problem is caused by your SIM network(Only ONE IP allowed).
No issue my side. Here’s my test result:
ATI
HL8548-G
AT+GPSAUTOINIT=0
AT+COPS?
+COPS: 0,0,“CHN-UNICOM”,2
AT+CGDCONT=4,“IP”,“3gnet”
AT+KCNXCFG=1,“GPRS”,“3gnet”
AT+KTCPCFG=1,0,“xxx.xxx.xxx.xxx”,5045
+KTCPCFG: 1
AT+KCNXUP=1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,1,0
AT+CGDCONT?
+CGDCONT: 1,“IP”,“3gnet”,“10.66.41.101”,0,0
+CGDCONT: 4,“IP”,“3gnet”,“0.0.0.0”,0,0
AT+KTCPCNX=1
+KTCP_IND: 1,1
AT+GPSNMEA=01
AT+GPSSTART=0 //10:44:53.980
+GPSEVINIT: 1
+GPSEVSUPL: 1
+GPSEVSTART: 1
AT+CGDCONT? //10:45:05.375
+GPSEVPOS: 0
AT+CGDCONT? //10:45:06.373
+CGDCONT: 4,“IP”,“3gnet”,“10.166.121.96”,0,0
AT+GPSSTOP
+GPSEVSTOP: 1
+GPSEVPOS: 0
AT+CGDCONT?
HI, Sierra_klin1
I used cold start in GPS func, but still error happens. I used the following at commands.
I don’t want to use AGPS. Are the following command correct?
AT
AT&K3
ATE0
AT+KTCPCLOSE=1
AT+KTCPDEL=1
AT+GPSSTOP
ATI3
AT+CGREG?
// AT+GPSSUPLCFG=0,“suplcn.sirf。com”,7276,1,0 SKIP THIS AT COMMAND
AT+GPSSUPLCFG?
AT+CGDCONT?
AT+KCNXUP=1
AT+KTCPCNX=1 // around here, the server detects a new connection
AT+GPSNMEA=01
AT+GPSSTART=3 // CHANGE: 3 means cold start
AT+CGDCONT?
AT+CGPADDR
AT+GPSSTOP
AT+KTCPSTAT=1
AT+KTCPSND=1,17
AAAAAAAAAA–EOF–Pattern– // the server receives nothing.
AT+KTCPSTAT=1
AT+CGDCONT?
AT
AT
AT&K3
AT&K3
ATE0
ATE0
AT+KTCPCLOSE=1
ERROR
AT+KTCPDEL=1
ERROR
AT+GPSSTOP
ERROR
ATI3
AT+CGREG?
+CGREG: 0,4
+GPSEVINIT: 1
AT+GPSSUPLCFG?
AT+CGDCONT?
+KTCPCFG: 1
AT+KCNXUP=1
+KCNX_IND: 1,4,1
AT+KTCPCNX=1
AT+GPSNMEA=01
+KCNX_IND: 1,1,0
+KTCP_IND: 1,1
AT+GPSSTART=3
AT+CGDCONT?
+GPSEVSTART: 1
AT+CGPADDR
+CGPADDR: 4,“100.68.215.140”
AT+GPSSTOP
+GPSEVSTOP: 1
+GPSEVPOS: 0
AT+KTCPSTAT=1
+KTCPSTAT: 3,-1,0,0
AT+KTCPSTAT=1
+KTCPSTAT: 3,-1,0,0
AT+KTCPSND=1,17
CONNECT
AAAAAAAAAA
+KCNX_IND: 1,0,0
+KTCP_NOTIF: 1,0
+KCNX_IND: 1,0,0
+KTCP_NOTIF: 1,0
AT+KTCPSTAT=1
+KTCPSTAT: 1,0,0,0
AT+CGDCONT?
Hi fyusuke,
To disable the AGPS, please send:
AT+CGDCONT=4 //Delete the APN to disable SUPL
AT+GPSSUPLCFG=0,“suplcn.sirf.com”,7276,0,0 //0: disable SUPL URC
Thanks a lot!
Ill find a Sim which allows several ip setting
