About sending and receiving message
Hello! I am developing an application with the modems Itegno WM10801+. I have some problem with it:
  1. I am unable to send and to receive characters which are not ASCII (I develop it for French speakers).
  2. When I send messages with it (using AT command),it add to my original message a code that I don’t expect.
Let me explain more: For example I send “hello man” . The message which is received is “AT+CMGR=19 hello man”
I am using C# under Microsoft Visual studio (.net framework) and I use AT commands.
Any one to help me please?
Thank you in advance
This is something, problem in your code.
If you could send the code, i may help you out
Hello.Thank you for answering.Here is the code in c#:
//Initialisation of the port
public void initialise()
Publique.cm.PortName = “COM8”;
Publique.cm.BaudRate = 115200;
Publique.cm.RtsEnable = true;
Publique.cm.DtrEnable = true;
Publique.cm.DataBits = 8;
Publique.cm.Encoding = Encoding.Default ;
string cmd = “AT+CMGF=1\r”;
try
Publique.cm.Open();
Publique.cm.Write(cmd);
Thread.Sleep(1000);
catch
Console.Writeline(“Error of com port”
bool sendsms(string mess,string dest)
try
            string cmd = "AT+CMGS=" + dest + "\r";
            Thread.Sleep(400);
            Publique.cm.DiscardOutBuffer();
            Publique.cm.DiscardInBuffer();
            Thread.Sleep(50);
            cm.Write(mes + '\x001a');
            Thread.Sleep(1000);
        catch (Exception ex)
                return false;
        return true;
string receive()
        try
           for (int i = 0; i <= 20; i++)
                try
                    string read = "AT+CMGR=" + i.ToString() + "\r";
                    Publique.cm.Write(read);
                    Thread.Sleep(400);
                    string message = Publique.cm.ReadExisting();
                    if (message.IndexOf("ERROR") >= 0 || message.Length == 0 || message.IndexOf("CMGD") > 0) continue;
                    return message;
                     continue;
         Console.Writeline("Reception error")
Hi
my suggestion is to after you submit the message to send using AT commands check for the response
OK or Error message from modem. also at+cmgs gives you receipt number.
intraduce some handshaking or query the receive buffer.
hope this will help you
Asiri
Hai friend,
I have seen your code. My suggestion is to use events like on serialport in vb6, we have a event in .net 2.0
try using system.io
you will find the event.
there you can handle, no need to write delays and all.
Hello Shivaprasad.I see what you are meaning.I checked events of the serialport.Only events about reception are availabe.But my problem about reception is when some body sends a non ascii caracter( for exemple é , à,ù).The caracter is replaced by ‘?’ or someting else.
About sending,can you sugest something?
Waasiri,I think you have a good Idea about my problem on sending.But How can I read the results of an AT command?
Thanks to you all.I am happy to meet persons who undestand what I am asking .
Hai is the baud rate problem. simple run the command AT+IPR=0 and the same code.
