Hi all,
i had an application that open a server with only one socket reserved:
my application do an +WIPCREATE=3,1,80,7,7 and waiting for incoming connections.
when some client try to connect to my server i recieve an +WIPACCEPT: 1,7 unsolicited code and swap in a reserved TA-TE link ( DATAMODE ) with command +WIPDATA.
if an another peer is trying to connect to my server during an in progress communication, even if i’m in DATAMODE, and I’m exchanging data with another client, i recieve +CME ERROR: 838 mixed with normal exchanging data. This may be result in a corrupted data communication.
My question: is there a way to disable this notification in reserved mode ? likewise +CMER or +CGEREP commands ?
or need to spawn more socket as possibile and close all incoming connection with +WIPCLOSE command when return in AT mode ?
or better, manage it deleting that unsolicited code from data ? ( more difficult )
As documented in WA_DEV_WISMO_UGD_012 REV 004 at page 184: “When no more communication index are available in the TCP server range, any peer trying to connect to the server will recieve an accept immediatly followed by a shutdown.” but there is no mention about that.
the error 838 is described as “no more free socket” at page 214 of the same document.
Suggestion ?
Thank you in advance.
