hello,
on software 657_09gg.Q2406B 1954500 102706 18:44, running on a Q2406 module, using the module in TCP client mode with GPRS bearer, when trying to connect to a server, if the server is not available, the command :
AT+WIPCREATE=2,1,“IP address”,port number
get the answer:
+CME ERROR: 831
+CME ERROR: 800
The problem is: when the server is available again, the command
AT+WIPCREATE=2,1,“IP address”,port number will faill again…
in order to connect, i need to use an increased socket index for example :
AT+WIPCREATE=2,2,“IP address”,port number
So the apllication software needs to increase the socket index at each retry, in order to be able to connect if the server is back…but when the socket index reaches 10 the command fails systematically, even if the server is running
As a matter of fact, if the server is unavailable for a long time, the application software is unable to connect when the server is back…
Do you know a workaround ?
do you know if this problem will be corrected ?
