[WP8548] Source code download
I am trying to build a Custom build for a WP8548 module, but am unable to download the source code Release 17: SWI9X15Y_07.14.01.00 Source here as clicking the link return a single text message : Not found.
Is there any other location where I can download the source code?
Jeremy
Have you tried leaf?
Thank for your response.
I thought that leaf was for the .cwe files.
So with the command leaf getsrc swi-linux in my workspace, it should be possible to download the yocto source code.
But if I understand correctly for that I need a Gerrit account and I can’t connect to: https://gerrit.legato.io
Do you have another solution?
Thank,
JérémyL
You can download here
https://source.sierrawireless.com/resources/airprime/software/wpx5xx/wpx5xx-firmware-latest-release-components/
In my first post the link
here
is a link to : https://source.sierrawireless.com/resources/airprime/software/wpx5xx/wpx5xx-firmware-latest-release-components/ .
and it is on this web site that I am unable to download the source code.
Thank,
JeremyL
the server seems to be down now.
Probably you need to try later for both
and
The source code is still not available at: https://source.sierrawireless.com/resources/airprime/software/wpx5xx/wpx5xx-firmware-latest-release-components/
and https://gerrit.legato.io is still not reachable.
Does anyone have another solution?
Thank you,
Jeremy L
Hi @JeremyL
We will check on this and update. You can use leaf to download the source package that you need. You can search using “leaf search -t wp85 - stable”.
Hi @JeremyL
I didn’t notice your post regarding gerrit earlier. My apologies.
We migrated external repositories from https://gerrit.legato.io to github, new documentation is available on GitHub - Legato Docs . We had sent notifications related to the same in January to all gerrit users regarding this switch.
Add external remote if it not already added.
  1. “leaf remote add external-stable https://downloads.sierrawireless.com/leaf/legato/stable.json”
Please check to see if the new swi-cloneutils can now be found in the external remote by running:
  1. “leaf search -a swi-cloneutils_5.0.210118”
If the package is found run the following command to install the tool in the leaf workspace:
  1. “leaf profile sync”
Additionally, there are additional steps required to access the repositories on github.
  1. follow instructions on GitHub - Legato Docs
Please let us know if this helps.
Hi @anon56110884
Thank you for your reply.
After some python version testing for the repo command, I was able to download the source code for the WP8548.
Thank you,
JeremyL
