Hi ,
We are unable to find the source of R16 Linux Distribution. It is showing “Not found” when we click the link.
Kindly note that we are looking for kernel and Yocto source together.
Kind Regards,
Raghu
Hi ,
Kind Regards,
Raghu
Hi raghukumar,
The link for downloading the Linux Distro Source (https://source.sierrawireless.com/) is not working now.
Probably you need to try later.
You can use the leaf to download the Linux Distribution source. The leaf is a development workspace manager designed to download, install and configure your development environment for Legato via VS Code or Linux command line.
Please refer to the below links for more information.
https://docs.legato.io/latest/tools_vsCode.html
https://docs.legato.io/latest/toolsLeaf.html
Help to tick “Solutions” if your question is answered.
You can also try on github.
I just tried on Ubuntu14, it is working fine for me:
https://docs.legato.io/latest/toolsGitHub.html
set up github account by browsing github.com (SSH or credential)
accept the license term by browsing the link on GitHub - Legato Docs
follow GitHub - Legato Docs to install repo script
download and sync the source by the following commands (the instruction on the webpage missed “proprietary”)
repo init -u ssh://git@github.com/legatoproject/manifest -m products/wp76xx/releases/Release16.xml -g default,-cache,proprietary
repo sync
make
Thanks for your reply,
I followed the document GitHub - Legato Docs
While cloning the manifest , I got the error(fatal: repository ‘https://github.com/legatoprojects/manifest/’ not found).
Regards,
Raghu
I did not type that command, I only type these two commands
repo sync
Hi Jyijyi,
Thanks. I use repo init command now. What python version should i use? I am getting syntax error. Pyhton3 is installed in my computer.
Regards,
Raghu
I used python 3.6 in ubuntu 14
