I have designed a custom PCB housing a WP8548 / WP7603, and stupidly missed the caviat on GPIO34 thru 37 stating only accessible via sysfs/Legato. I have searched high 'n low to find out how I actually do that now that I have connected external inputs to these pins.
This might well be a no-brainer for a experienced linux programmer, but alas I am not…
Could somebody give me a code example that reads the state of these pins within an API please ?
Thank you in advance.
Steve
For those that have hit this before, here is what I did to solve the issue…
I noticed on the Mangoh forum a post not entirely relating to my issue :-
forum.mangoh.io/t/controlling-wp … roblem/984
I had already for each GPIO I needed applied :-
AT+WIOCFG=<GPIO#>,16,0,0,1,0,0
In the AT Command console.
then within the main console I executed from /sys/class/gpio folder :-
echo <GPIO#> > export
where <GPIO#> is the GPIO number.
Once I applied the above, I can now use the GPIO’s within my API.
I also tested this re-configure is non-volatile.
Thanks.
