larry1
#1
Hi ,
I have a WP7702 with mangoh yellow
AT!PCINFO?
State: Low Power Mode
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:1, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
LPM persistence - None
AT!ENTERCND=“A710”
AT!CUSTOM=“CFUNPERSISTEN”,01
reset
at!reset
AT!ENTERCND=“A710”
AT!ENTERCND=“A710”
AT+CFUN=1
AT+CFUN=1
+CME ERROR: operation not supported
I stuck in LPM
how can I leave the mode “W_DISABLE” ?
Dear customer,
In order to troubleshoot the problem, please help provide answer for below items:
- Did you perform any upgrade process before getting the problem? If yes, please share upgrade path (which FW version did you try from/to)
- Did you try to reflash FW? How is result?
- Please share output of the following AT commands
AT!ENTERCND=“A710”
ATI9
ATI8
AT!IMPREF?
AT!IMAGE?
AT!PRIID?
larry1
#3
Hi @LemonGreen
Thanks for your reply.
I use command “AT!PCOFFEN=2” to solve the status.
So my question is when will happen W_DISABLE ?
