WP7702 Reboot on low gsm signal
Hello, got a WP7702 on a mangoH board. We use socket connection to send data (round 1 position info each 2 seconds), and it works perfectly when network coverage is strong. When same module have low network coverage we observ random reboot during transmission. Can you help us investigate the reason of reboot? Is there some sort of log we can read?
In cm info we read:
Device: WP7702
IMEI: 352653090194176
IMEISV: 6
FSN: 4L931388970810
Firmware Version: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
Bootloader Version: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
MCU Version: 002.015
PRI Part Number (PN): 9909138
PRI Revision: 001.001
Carrier PRI Name: GENERIC
Carrier PRI Revision: 001.071_001
SKU: 1104405
Last Reset Cause: Power Down
Resets Count: Expected: 324 Unexpected: 0
so reboot seem to be expected. Usually it happen on 2G networks.
Thanks in advance.
Gianmaria.
Hi @gi1
You can execute “logread -f” on the app core and monitor the logs. It’s most likely due to insufficient power.
Please check if enough power is being provided to the modem. The WP7702’s power consumption values are provided in it’s technical specs https://source.sierrawireless.com/resources/airprime/hardware_specs_user_guides/airprime_wp77xx_product_technical_specification.
Please refer the power supply sources section for mangOH as well.
I suspected this since first problems and so i used a MacBook powerAc to power it on…
but maybe there is some limitations in hardware, maybe the usb port is not capable to give enough power to the modem during high consumption/transmission.
logread -f & does not produces any log about it. It just restarts. No error of any type were signaled in log. Is there some other log i can enable? Or read?
I have to wait for the prototype of the product, where i will have only the modem and the accelerometer and some other stuff (a led, the sim, the gps antenna).
It’s so courious as there is no log and no info on reset cause, or at least it seems that the reset was software requested… “Resets Count: Expected: 325 Unexpected: 0”.
gianmaria
below the log…this is all i can read before reboot… but i cant understand what’s going on o r what is restarting the device.
Regards,
Gianmaria
root@swi-mdm9x28-wp:~# Jan 6 03:05:37 swi-mdm9x28-wp user.err Legato: =ERR= | avcDaemon[1736]/avcDaemon T=main | avcAppUpdate.c avcApp_SetSwUpdateResult() 2948 | No update is going on. CurrentObj9 = null
Jan 6 03:05:37 swi-mdm9x28-wp user.err Legato: =ERR= | avcDaemon[1736]/avcDaemon T=main | avcAppUpdate.c avcApp_SetSwUpdateState() 3013 | No update is going on. CurrentObj9 = null
Jan 6 03:05:38 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:38 swi-mdm9x28-wp user.err Legato: QMUXD: WARNING qmi_qmux_if_pwr_up_init failed! rc=-6
Jan 6 03:05:38 swi-mdm9x28-wp user.err Legato: =ERR= | avcDaemon[1736]/avcDaemon T=main | assetData.c assetData_RegistrationUpdate() 1951 | unsupported function called.
Jan 6 03:05:39 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:40 swi-mdm9x28-wp user.err qti: QMUXD: WARNING qmi_qmux_if_pwr_up_init failed! rc=-6
Jan 6 03:05:40 swi-mdm9x28-wp user.warn kernel: [ 37.201798] USB QCMAP NL IOCTL Snd GETNEIGH Succ
Jan 6 03:05:40 swi-mdm9x28-wp user.warn kernel: [ 37.327264] USB QCMAP NL IOCTL Snd GETNEIGH Succ
Jan 6 03:05:40 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:41 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:42 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:43 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:44 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:45 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:46 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:47 swi-mdm9x28-wp user.debug lowtempfix: tmrHandler returns temperature as 39
Jan 6 03:05:47 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:48 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:49 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:50 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:51 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:52 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:53 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:54 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:55 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:56 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:57 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 799 | Sending QMI_NAS_GET_NETWORK_TIME_RESP_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=74.[0x4a]
Jan 6 03:05:57 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/modemDaemon T=main | le_mrc.c RetrySyncNetworkTimeHandler() 1813 | Unable to sync network time from the modem: result -6
Jan 6 03:07:04 swi-mdm9x28-wp user.info kernel: [ 121.441083] sierra_startup_monitor
Jan 6 03:20:14 swi-mdm9x28-wp authpriv.warn login[1626]: invalid password for ‘UNKNOWN’ on ‘/dev/ttyHSL1’
Jan 6 03:20:19 swi-mdm9x28-wp authpriv.notice login[1626]: ROOT LOGIN on ‘/dev/ttyHSL1’
Jan 6 03:20:25 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2214 | SessionRef (0x7f5fd9e0) has been closed
Jan 6 03:29:02 swi-mdm9x28-wp user.debug kernel: [ 1439.277151] gpio_map_name_to_num: find GPIO 8
Jan 6 03:29:02 swi-mdm9x28-wp user.err Legato: =ERR= | posDaemon[1860]/posDaemon T=main | le_gnss.c le_gnss_Stop() 3742 | Bad state for that request [1]
Jan 6 03:29:17 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2214 | SessionRef (0x7f5fd8b0) has been closed
Jan 6 03:29:20 swi-mdm9x28-wp user.err Legato: =ERR= | modemDaemon[1841]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2214 | SessionRef (0x7f5fe7f8) has been closed
Jan 6 04:05:47 swi-mdm9x28-wp user.debug lowtempfix: tmrHandler returns temperature as 40
Jan 6 04:06:12 swi-mdm9x28-wp user.notice kernel: [ 3669.875727] audit: type=1400 audit(315972372.828:2): lsm=SMACK fn=smack_unix_may_send action=denied subject=“app.environment” object=“syslog” requested=w pid=1792 comm=“bme680EnvSensor” path="/dev/log"
Jan 6 04:06:12 swi-mdm9x28-wp user.notice kernel: [ 3669.875923] audit: type=1400 audit(315972372.828:3): lsm=SMACK fn=smack_inode_permission action=denied subject=“app.environment” object=“app.environmentrwx” requested=x pid=1792 comm=“bme680EnvSensor” name=“environment” dev=
Jan 6 04:06:12 swi-mdm9x28-wp user.notice kernel: [ 3669.878470] audit: type=1400 audit(315972372.828:4): lsm=SMACK fn=smack_unix_may_send action=denied subject=“app.environment” object=“syslog” requested=w pid=1793 comm=“dataHubConnecto” path="/dev/log"
Jan 6 04:06:12 swi-mdm9x28-wp user.notice kernel: [ 3669.878824] audit: type=1400 audit(315972372.828:5): lsm=SMACK fn=smack_inode_permission action=denied subject=“app.environment” object=“app.environmentrwx” requested=x pid=1793 comm=“dataHubConnecto” name=“environment” dev=
Jan 6 04:06:27 swi-mdm9x28-wp user.crit Legato: CRT | audioDaemon[1726]/framework T=main | signals.c TermSignalHandler() 449 | Terminated
Jan 6 04:08:25 swi-mdm9x28-wp user.crit Legato: CRT | watchdog[1142]/watchdogDaemon T=main | watchdog.c WatchdogHandleExpiry() 488 | Mandatory watchdog double fault on process [audioService][audioDaemon]
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | watchdog[1142]/le_pa_wdog T=main | pa_wdog.c pa_wdog_Shutdown() 72 | Watchdog expired. Restart device.
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | supervisor[1062]/supervisor T=main | frameworkDaemons.c fwDaemons_SigChildHandler() 523 | Framework daemon ‘watchdog’ has exited with code 1.
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | portDaemon[1851]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (portDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | powerManagerService[1869]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (powerManagerService.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | modemDaemon[1841]/framework T=MrcProcessThread | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (modemDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | posDaemon[1860]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (posDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | fwupdateDaemon[1802]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (fwupdateDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | secStore[1890]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (secStore.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | gpioService[1814]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (gpioService.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | cellNetService[1763]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (cellNetService.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | dcsInternal[1774]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (dcsInternal.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | avcDaemon[1736]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (avcDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | atClientDaemon[1716]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (atClientDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | dcsDaemon[1773]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (dcsDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | atQmiLinker[1707]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (atQmiLinker.atQmiLinker.le_port:83a0274de10851a9e4ec565408775fc3).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | atServerDaemon[1717]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (atServerDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | atAirVantage[1698]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (atAirVantage.atAirVantage.le_port:83a0274de10851a9e4ec565408775fc3).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | location[3947]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (location.locationComponent.le_posCtrl:d47cc30512e69387f546399a44c565e4).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | smsManager[3951]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (smsManager.smsComponent.location:5529bd09de0bb58f6aa9bd9b152d7cc1).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | qmiAirVantage[1881]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (qmiAirVantage.qmiAirVantage.le_atServer:b7ddff0d499d71d3a23372d9447cbc78).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | NtagDhubIf[1689]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (NtagDhubIf.NtagDhubIfComponent.fieldDetectGpio:eb4b6dc575d64f27484e7657275f11fd).
Jan 6 02:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | button[1754]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (gpio:eb4b6dc575d64f27484e7657275f11fd).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | networkMonitor[3948]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (networkMonitor.networkComponent.le_data:03dd7258d7c4181a8a37c90e3d1e73a9).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | monitor[3946]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (monitor.monitorComponent.le_gpioPin21:eb4b6dc575d64f27484e7657275f11fd).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | rSimDaemon[1842]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (rSimDaemon.watchdogChain.le_wdog:572ba176b790548eed89b7ba6f9f4b14).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | networkManager[3949]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (networkManager.networkChannelComponent.le_info:975257ab76b4bd700b883f96a47b6508).
Jan 6 04:08:25 swi-mdm9x28-wp user.emerg Legato: EMR | orchestrator[3950]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (orchestrator.orchestratorComponent.networkManager:d9091a9841ee1045170fae530cc9ef9a).
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | supervisor[1062]/supervisor T=main | supervisor.c framework_Reboot() 811 | Supervisor going down to trigger reboot.
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | dataHub[1783]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (le_appInfo:092c2f7994c22cecc1e5a2608e1595b0).
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | battery[1745]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (dhubIO:a2dafb94eca240de32c6cbd223a593ba).
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | lightSensor[1832]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (dhubIO:a2dafb94eca240de32c6cbd223a593ba).
Jan 6 02:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | imu[1823]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (imu.periodicSensor.dhubIO:a2dafb94eca240de32c6cbd223a593ba).
Jan 6 02:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | vegas[1899]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (dhubIO:a2dafb94eca240de32c6cbd223a593ba).
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7237]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7226]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7230]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7233]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7236]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7242]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7249]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7243]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7244]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7246]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7251]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7248]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7250]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7253]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7252]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7254]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
}ᕁj 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: Mѽ
=MPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7258]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7259]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app na[ 3805.415504] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister ecm0
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7260]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7261]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7262]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
rcK: Ex[ 3805.490325] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister ecm0
ecuting run_K_scripts…
no port_bridge found; none killed
Stopping qmi_ip: no qmi_ip_multiclient found; none killed
Stopping eMBMs_TunnelingModule: no eMBMs_TunnelingModule found; none killed
Stopping netmgrd: stopped netmgrd (pid 1338)
done
Stopping qmuxd: stopped qmuxd (pid 1272)
done
no QCMAP_ConnectionManager found; none killed
Stopping fs-scrub-daemon: no fs-scrub-daemon found; none killed
Stopping thermal-engine: stopped thermal-engine (pid 1285)
done
stopped qti (pid 1593)
Stopping reboot daemon: stopped reboot-daemon (pid 1219)
done
Legato shutdown sequence
Service Directory still running. Killing it now …
DONE.
umount: can’t unmount /legato: Device or resource busy
Finished Legato stop Sequence
stopping time daemon
Stopping time_services: stopped time_daemon (pid 797)
done
stopping ntpd
no ntpd found; none killed
Stopping diagrebootapp: stopped diagrebootapp (pid 767)
done
stopping DNS forwarder and DHCP server: dnsmasq… stopped /usr/bin/dnsmasq (pid 823)
done.
Deconfiguring network interfaces… ifdown: interface eth0 not configured
done.
Stopping syslogd/klogd: stopped syslogd (pid 698)
stopped klogd (pid 708)
done
Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 1541)
dropbear.
K96mount_unionfs: RO rootfs fudge allowed.
Stopping system message bus: dbus.
K98mount_early: Executing mount_early_user_stop…
K98mount_early: RO rootfs fudge allowed.
K98mount_early: ubidetach failed for device /dev/mtd16, rcK should take care of it.
K98mount_early: Executing mount_early_legato_stop…
Can’t get valid SMEM, init DSSD SMEM
Linux sub system 1
K98mount_early: Executing mount_early_userrw_stop…
K98mount_early: Executing mount_early_unset_timezone…
rcK: Executing kill_all_proc…
rcK: Executing umount_fs_generic…
rcK: Executing print_shutdown_msg…
** SYSTEM SHUTDOWN COMPLETE **
The system is going down NOW!
Sent SIGTERM to all processes
[ 3810.181085] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister bridge0
[ 3810.200353] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister bridge0
Requesting system rebootesses
[ 3812.162682] reboot: Restarting system
[ 3812.166218] Failed to disable secure wdog debug: -4
[ 3812.170189] Calling SCM to disable SPMI PMI
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.2-00096
S - IMAGE_VARIANT_STRING=LAATANAZA
S - OEM_IMAGE_VERSION_STRING=SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:07:21
More log here…
Jan 6 04:08:25 swi-mdm9x28-wp user.info Legato: INFO | networkManager[3949]/networkChannelComponent T=main | networkManager.c reveice_handler() 120 | receive errno: Resource temporarily unavailable 11
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7255]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:26 swi-mdm9x28-wp user.emerg Legato: EMR | _appStopClient[7259]/appStopClient_exe T=main | appStopClient.c _appStopClient_exe_COMPONENT_INIT() 53 | Error sending app name to the AppStop server socket. Connection refused
Jan 6 04:08:28 swi-mdm9x28-wp user.emerg Legato: EMR | startSystem[1051]/framework T=main | start.c RunCurrentSystem() 1685 | System will reboot now !
Jan 6 02:08:28 swi-mdm9x28-wp daemon.info : starting pid 7282, tty ‘’: ‘/etc/init.d/rcK’
Jan 6 04:08:28 swi-mdm9x28-wp user.err kernel: [ 3805.415504] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister ecm0
Jan 6 04:08:28 swi-mdm9x28-wp user.err kernel: [ 3805.490325] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister ecm0
Jan 6 04:08:28 swi-mdm9x28-wp user.info qmi_shutdown_modem: subsystem_control_shutdown
Jan 6 04:08:28 swi-mdm9x28-wp user.err qmi_shutdown_modem: QMUXD: WARNING qmi_qmux_if_pwr_up_init failed! rc=-6
Jan 6 04:08:28 swi-mdm9x28-wp user.info qmi_shutdown_modem: Initialize QMI DMS Client
Jan 6 04:08:28 swi-mdm9x28-wp user.info qmi_shutdown_modem: Current Modem status - 0
Jan 6 04:08:28 swi-mdm9x28-wp user.info qmi_shutdown_modem: Move modem status to LPM
Jan 6 04:08:28 swi-mdm9x28-wp user.info qmi_shutdown_modem: Wait for modem LPM complete
Jan 6 04:08:28 swi-mdm9x28-wp user.warn kernel: [ 3805.592884] USB QCMAP NL IOCTL Snd GETNEIGH Succ
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: DMS indication id - 1
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: Modem in LPM state… proceed with rest of shutdown procedure
Jan 6 04:08:30 swi-mdm9x28-wp user.warn kernel: [ 3807.519302] PSM: Modem oprt mode - 1
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: In the shutdown path
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: Received subsystem shutdown complete in 3 second(s)
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: Success.
Jan 6 04:08:30 swi-mdm9x28-wp user.info qmi_shutdown_modem: Modem shutdown complete
Jan 6 04:08:31 swi-mdm9x28-wp user.warn kernel: [ 3807.843468] Stopping port_bridge:
Jan 6 04:08:31 swi-mdm9x28-wp user.warn kernel: [ 3808.143419] Stopping QCMAP_ConnectionManager: Stopping qti: done
Jan 6 04:08:31 swi-mdm9x28-wp user.crit Legato: CRT | serviceDirectory[1084]/framework T=main | signals.c TermSignalHandler() 449 | Terminated
Jan 6 04:08:31 swi-mdm9x28-wp user.emerg Legato: EMR | logCtrlDaemon[1086]/framework T=main | messagingInterface.c DirectorySocketClosed() 607 | Connection to Service Directory lost for service (logFd:f871a40b4c7617a93b47f874956f1e69).
Jan 6 04:08:31 swi-mdm9x28-wp user.emerg Legato: EMR | configTree[1087]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (LogClient:LogControlProtocol).
Jan 6 04:08:31 swi-mdm9x28-wp user.emerg Legato: EMR | updateDaemon[1091]/framework T=main | messagingSession.c ClientSocketHangUp() 873 | Session closed by server (LogClient:LogControlProtocol).
Jan 6 04:08:31 swi-mdm9x28-wp user.warn kernel: [ 3808.855525] stopping lowtempfix
Jan 6 04:08:31 swi-mdm9x28-wp user.info lowtempfix: signal received, releasing wake lock unconditionally
Jan 6 04:08:32 swi-mdm9x28-wp user.err time_daemon_mdm:[797]: Received signal terminating service
Jan 6 04:08:32 swi-mdm9x28-wp user.err time_daemon_mdm:[797]: Time-services exitting …
Jan 6 04:08:32 swi-mdm9x28-wp daemon.info dnsmasq[823]: exiting on receipt of SIGTERM
