I am currently using the WP7609 module.
After building an application with the following command:
mkapp -t wp76xx app.adef
and installing it on the WP7609 using:
app install app.wp76xx.update 192.168.2.2
the wireless network connection gets disconnected.
I tried reconnecting using:
cm data connect
However, while the application is running, the connection disconnects again.
Even after restarting the WP7609, the wireless network remains disconnected.
- adef file
sandboxed: false
start: auto
maxFileSystemBytes: 110000K
maxMemoryBytes: 110000K
maxMQueueBytes: 110000K
executables:
app_exe = ( appComponent )
processes:
envVars:
LE_LOG_LEVEL = INFO
run:
( app_exe )
faultAction: restart
watchdogAction: restart
maxCoreDumpFileBytes: 110000K
maxFileBytes: 110000K
maxLockedMemoryBytes: 110000K
requires:
device:
[rw] /dev/ttyAT /dev/ttyAT
bindings:
app_exe.appComponent.le_led_r -> <root>.le_gpioPin32
app_exe.appComponent.le_led_g -> <root>.le_gpioPin33
app_exe.appComponent.le_led_b -> <root>.le_gpioPin42
app_exe.appComponent.le_gnss -> positioningService.le_gnss
app_exe.appComponent.le_spi -> spiService.le_spi
app_exe.appComponent.le_sim -> modemService.le_sim
app_exe.appComponent.le_mrc -> modemService.le_mrc
app_exe.appComponent.le_atClient -> atService.le_atClient
- Component.cdef
sources:
cflags:
-g -O0
-I$CURDIR/include
requires:
api:
le_led_r = $LEGATO_API/interfaces/le_gpio.api
le_led_g = $LEGATO_API/interfaces/le_gpio.api
le_led_b = $LEGATO_API/interfaces/le_gpio.api
le_gnss = $LEGATO_API/interfaces/positioning/le_gnss.api
le_spi = $LEGATO_API/interfaces/le_spi.api
le_sim = $LEGATO_API/interfaces/modemServices/le_sim.api
le_mrc = $LEGATO_API/interfaces/modemServices/le_mrc.api
le_atClient = $LEGATO_API/interfaces/atServices/le_atClient.api
- Question
- Why does the network disconnect after installing and running this application?
- Is there any configuration or permission issue in the adef file that could cause this?
- Are there known issues when using le_mrc, le_sim, or le_atClient that could impact the data connection?
Any help or guidance would be appreciated.
Thank you.
