Dear Team,
Below are the issues faced while testing the application through onboard WP7608 module placed in our carrier board.
- While checking the internet connectivity, network is disconnecting after 10-15 mins and again, its unable to connect to the internet with WP7608 module
Case-1:.Below Scenario we have tested and the Network we selected is AIRTEL
Following are the test case i have tried so using below set of commands to connect the internet from the HOST.
$ ifconfig wwan0 down
$ echo Y > /sys/class/net/wwan0/qmi/raw_ip
$ ifconfig wwan0 up
$ qmi-network /dev/cdc-wdm0 start
$ udhcpc -i wwan0
root@phyboard-mira-imx6-14:~# ping google.com
PING google.com (172.217.160.142): 56 data bytes
64 bytes from 172.217.160.142: seq=0 ttl=55 time=63.395 ms
64 bytes from 172.217.160.142: seq=1 ttl=55 time=45.048 ms
64 bytes from 172.217.160.142: seq=2 ttl=55 time=41.914 ms
64 bytes from 172.217.160.142: seq=3 ttl=55 time=41.550 ms
64 bytes from 172.217.160.142: seq=4 ttl=55 time=42.220 ms
64 bytes from 172.217.160.142: seq=5 ttl=55 time=40.950 ms
64 bytes from 172.217.160.142: seq=6 ttl=55 time=52.766 ms
64 bytes from 172.217.160.142: seq=7 ttl=55 time=42.527 ms
64 bytes from 172.217.160.142: seq=8 ttl=55 time=52.323 ms
64 bytes from 172.217.160.142: seq=9 ttl=55 time=41.119 ms
Note:- After 10-15 mins the ping stops, and its works only after reconnecting using below set of commands
$ qmi-network /dev/cdc-wdm0 stop
$ udhcpc -i wwan0
