Q2698 - Network disconnection very frequent
Dear All,
I am finding a peculiar problem with Q2689 module, where when application is not running(wopen:0); module registers to the n/w and it will detects from the n/w next 10 seconds on its own; below are some of the captures available…
Kindly suggest…it tried all the n/w re-try commands such as AT+WBHV=9,1;at+COPS=0;AT+CREG=1…Uaually n/w should register on its own, but with Q2689 its stays without searching for n/w again.(n/w Flash LED : always ON)
AT
+WIND: 1
+CREG: 2
+CREG: 0
+CGREG: 0
+WIND: 7
+CREG: 2
+CREG: 1,“0462”,“0000A9BB”,0
+CGREG: 1,“0462”,“0000A9BB”,0
+WIND: 15,3,"+22",4,“15/03/09,06:54:52+22”,6,“0”
+WIND: 16
+CGEV: ME DETACH
+CGREG: 0
+CREG: 2
+WIND: 4
+WIND: 10,“SM”,0,“FD”,0,“ON”,0,“SN”,0,“EN”,0
BR
Are you saying that the behaviour is different when an application is running?
But +CREG: 2 means that it is searching!
:confused:
Have you tried using to AT+CCED to see what signal level and how many cells the device is seeing… :question:
When the application is application is running, the behaviors is same ;
secondly +CREG:2, we just kept it for hours time, it did not connected to n/w
for AT+CCED, below is the response
at+cced=0,3
+CCED: 0,404,45,1122,00001000,13,61,32,0,255,404,45,ffff,0,59,7
OK.
thanks
BR
