Hi, I’m using the WP7607 in a monitoring application, where I want to control some machinery and their status, and I’ve installed all the tools and scripts that let me do this inside /home/root. It has been working fine for a couple of weeks, until a series of power losses have cleaned everything I’ve put inside the /home and /etc. I’ve conducted some tests and I have found out that they both reside in /mnt/flash, and after putting a WP through a series of power losses, I’ve been able to replicate the issue:
ima: setting up IMA subsystem...
ima: feature not supported
The proc node does not exist
mount root fs from partition (rootfs|system)
UBI device number 0, total 120 LEBs (30474240 bytes, 29.0 MiB), available 0 LEBs (0 bytes), LEB size 253952 bytes (248.0 KiB)
dm-verity key not installed, authentication disabled
Non-Secure version.
rootfs roothash set at compile time: 083b306ba8b4678734d2a68e980c583ffda32ac7e5c2c8d8579aa446abe1fa91
rootfs: dev '/dev/ubiblock0_0' 'squashfs'
mount /dev/mapper/rt
rootfs: mounting took 0ms
init started: BusyBox v1.27.2 (2020-10-22 09:40:46 UTC)
rcS: Executing mount_essential_fs...
rcS: Executing simple_network...
rcS: Executing run_S_scripts...
S02mount_early: Executing mount_early_pseudo...
S02mount_early: Mounting SMACK security pseudo fs...
S02mount_early: Executing mount_early_other...
S02mount_early: Executing mount_early_create_dirs...
S02mount_early: Executing mount_early_set_timezone...
S02mount_early: Using timezone Universal...
S02mount_early: Executing yaffs2_kern_supported_init...
S02mount_early: Executing mount_early_user_start...
S02mount_early: RO rootfs fudge allowed.
S02mount_early: User is forcing userapp file system to be ubifs.
S02mount_early: Trying to mount UBIFS on /mnt/flash using [usrquota,grpquota,rw] mount options...
[ 6.410107] SWI ssmem_alloc_entry_get: ssmem region 20 not allocated
[ 6.415421] SWI ssmem_get: ssmem_get: region 20 not exists
UBI device number 3, total 524 LEBs (133070848 bytes, 126.9 MiB), available 5 LEBs (1269760 bytes, 1.2 MiB), LEB size 253952 bytes (248.0 KiB)
[ 7.542181] UBIFS error (ubi3:0 pid 331): grab_empty_leb: could not find an empty LEB
[ 7.548982] (pid 331) start dumping LEB properties
[ 7.553795] (pid 331) Lprops statistics: empty_lebs 0, idx_lebs 10
[ 7.560005] taken_empty_lebs 0, total_free 700416, total_dirty 66986680
[ 7.566746] total_used 49903240, total_dark 3727360, total_dead 0
[ 7.573145] LEB 10 free 0 dirty 251264 used 2688 free + dirty 251264 dark 8192 dead 0 nodes fit 59 flags 0x1 (dirty)
[ 7.585629] LEB 11 free 0 dirty 251752 used 2200 free + dirty 251752 dark 8192 dead 0 nodes fit 59 flags 0x1 (dirty)
[ 7.598279] LEB 12 free 0 dirty 245800 used 8152 free + dirty 245800 dark 8192 dead 0 nodes fit 57 flags 0x1 (dirty)
[ 7.610874] LEB 13 free 0 dirty 125488 used 128464 free + dirty 125488 dark 8192 dead 0 nodes fit 29 flags 0x1 (dirty)
[ 7.623547] LEB 14 free 0 dirty 249576 used 4376 free + dirty 249576 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
#... THERE ARE A LOT OF THOSE ...#
[ 13.574855] LEB 470 free 0 dirty 99024 used 154928 free + dirty 99024 dark 8192 dead 0 nodes fit 23 flags 0x0 (not categorized)
[ 13.588395] LEB 471 free 0 dirty 249128 used 4824 free + dirty 249128 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
[ 13.601071] LEB 472 free 0 dirty 114472 used 139480 free + dirty 114472 dark 8192 dead 0 nodes fit 26 flags 0x0 (not categorized)
[ 13.614611] LEB 473 free 0 dirty 249208 used 4744 free + dirty 249208 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
[ 13.627285] LEB 474 free 0 dirty 119832 used 134120 free + dirty 119832 dark 8192 dead 0 nodes fit 28 flags 0x0 (not categorized)
[ 13.640825] (pid 331) finish dumping LEB properties
[ 13.645689] (pid 331) Budgeting info: data budget sum 0, total budget sum 0
[ 13.652674] budg_data_growth 0, budg_dd_growth 0, budg_idx_growth 0
[ 13.658962] min_idx_lebs 8, old_idx_sz 510584, uncommitted_idx 25536
[ 13.665431] page_budget 4144, inode_budget 160, dent_budget 312
[ 13.671415] nospace 0, nospace_rp 0
[ 13.674935] dark_wm 8192, dead_wm 4096, max_idx_node_sz 192
[ 13.680620] freeable_cnt 0, calc_idx_sz 497344, idx_gc_cnt 0
[ 13.686304] dirty_pg_cnt 0, dirty_zn_cnt 133, clean_zn_cnt 6
[ 13.692077] gc_lnum -1, ihead_lnum 71
[ 13.695769] jhead 0 (GC) LEB 128
[ 13.699159] jhead 1 (base) LEB 74
[ 13.702670] jhead 2 (data) LEB 145
[ 13.706188] bud LEB 18
[ 13.708614] bud LEB 25
[ 13.711087] bud LEB 26
[ 13.713479] bud LEB 33
[ 13.715904] bud LEB 48
[ 13.718339] bud LEB 56
[ 13.720811] bud LEB 72
[ 13.723203] bud LEB 74
[ 13.725629] bud LEB 83
[ 13.728063] bud LEB 114
[ 13.730619] bud LEB 128
[ 13.733092] bud LEB 134
[ 13.735616] bud LEB 145
[ 13.738131] bud LEB 147
[ 13.740704] bud LEB 162
[ 13.743168] commit state 0
[ 13.745947] Budgeting predictions:
[ 13.749331] available: 61393272, outstanding 0, free 57995120
mount: mounting /dev/ubi3_0 on /mnt/flash failed: No space left on device
S02mount_early: Unable to mount /dev/ubiblock3_0 onto /mnt/flash.
S02mount_early: Trying to mount UBIFS on /mnt/flash using [rw] mount options...
[ 15.302980] UBIFS error (ubi3:0 pid 376): grab_empty_leb: could not find an empty LEB
[ 15.309782] (pid 376) start dumping LEB properties
[ 15.314891] (pid 376) Lprops statistics: empty_lebs 0, idx_lebs 10
[ 15.320844] taken_empty_lebs 0, total_free 700416, total_dirty 66986680
[ 15.327489] total_used 49903240, total_dark 3727360, total_dead 0
[ 15.333688] LEB 10 free 0 dirty 251264 used 2688 free + dirty 251264 dark 8192 dead 0 nodes fit 59 flags 0x1 (dirty)
[ 15.346325] LEB 11 free 0 dirty 251752 used 2200 free + dirty 251752 dark 8192 dead 0 nodes fit 59 flags 0x1 (dirty)
[ 15.358999] LEB 12 free 0 dirty 245800 used 8152 free + dirty 245800 dark 8192 dead 0 nodes fit 57 flags 0x1 (dirty)
[ 15.371673] LEB 13 free 0 dirty 125488 used 128464 free + dirty 125488 dark 8192 dead 0 nodes fit 29 flags 0x1 (dirty)
[ 15.384346] LEB 14 free 0 dirty 249576 used 4376 free + dirty 249576 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
[ 21.324368] LEB 470 free 0 dirty 99024 used 154928 free + dirty 99024 dark 8192 dead 0 nodes fit 23 flags 0x0 (not categorized)
[ 21.337908] LEB 471 free 0 dirty 249128 used 4824 free + dirty 249128 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
[ 21.350642] LEB 472 free 0 dirty 114472 used 139480 free + dirty 114472 dark 8192 dead 0 nodes fit 26 flags 0x0 (not categorized)
[ 21.364125] LEB 473 free 0 dirty 249208 used 4744 free + dirty 249208 dark 8192 dead 0 nodes fit 58 flags 0x1 (dirty)
[ 21.376802] LEB 474 free 0 dirty 119832 used 134120 free + dirty 119832 dark 8192 dead 0 nodes fit 28 flags 0x0 (not categorized)
[ 21.390334] (pid 376) finish dumping LEB properties
[ 21.395199] (pid 376) Budgeting info: data budget sum 0, total budget sum 0
[ 21.402182] budg_data_growth 0, budg_dd_growth 0, budg_idx_growth 0
[ 21.408479] min_idx_lebs 8, old_idx_sz 510584, uncommitted_idx 25536
[ 21.414940] page_budget 4144, inode_budget 160, dent_budget 312
[ 21.420932] nospace 0, nospace_rp 0
[ 21.424452] dark_wm 8192, dead_wm 4096, max_idx_node_sz 192
[ 21.430137] freeable_cnt 0, calc_idx_sz 497344, idx_gc_cnt 0
[ 21.435820] dirty_pg_cnt 0, dirty_zn_cnt 133, clean_zn_cnt 6
[ 21.441594] gc_lnum -1, ihead_lnum 71
[ 21.445285] jhead 0 (GC) LEB 128
[ 21.448667] jhead 1 (base) LEB 74
[ 21.452177] jhead 2 (data) LEB 145
[ 21.455696] bud LEB 18
[ 21.458130] bud LEB 25
[ 21.460603] bud LEB 26
[ 21.462994] bud LEB 33
[ 21.465420] bud LEB 48
[ 21.467854] bud LEB 56
[ 21.470330] bud LEB 72
[ 21.472712] bud LEB 74
[ 21.475147] bud LEB 83
[ 21.477572] bud LEB 114
[ 21.480124] bud LEB 128
[ 21.482605] bud LEB 134
[ 21.485130] bud LEB 145
[ 21.487645] bud LEB 147
[ 21.490196] bud LEB 162
[ 21.492678] commit state 0
[ 21.495458] Budgeting predictions:
[ 21.498840] available: 61393272, outstanding 0, free 57995120
ubiformat: mtd16 (nand), size 137363456 bytes (131.0 MiB), 524 eraseblocks of 262144 bytes (256.0 KiB), min. I/O size 4096 bytes
libscan: scanning eraseblock 523 -- 100 % complete
ubiformat: 524 eraseblocks have valid erase counter, mean value is 14
ubiformat: formatting eraseblock 523 -- 100 % complete
UBI device number 3, total 524 LEBs (133070848 bytes, 126.9 MiB), available 480 LEBs (121896960 bytes, 116.2 MiB), LEB size 253952 bytes (248.0 KiB)
S02mount_early: Making single volume, size 115MiB on UBI device number 3...
Volume ID 0, size 475 LEBs (120627200 bytes, 115.0 MiB), LEB size 253952 bytes (248.0 KiB), dynamic, name "userapp_vol0", alignment 1
S02mount_early: Performing quota check on file system mounted at /mnt/flash
S02mount_early: UBIFS volume successfully mounted on /mnt/flash
S02mount_early: Executing mount_early_legato_start...
mount Legato from partition lefwkro
UBI device number 2, total 35 LEBs (8888320 bytes, 8.4 MiB), available 0 LEBs (0 bytes), LEB size 253952 bytes (248.0 KiB)
Non-Secure version.
S02mount_early: SQUASHFS successfully mounted on /mnt/legato
It seems like that the userapp partition gets corrupted and S02mount_early just wipes it up. Even if it didn’t wipe the partition (by modifying the script in a Yocto custom build), I haven’t been able to restore it by hand.
I’ve also tried putting the whole OS under readonly, which after a lot of headaches, I have been able to do (OverlayFS was a lot stubborn and a ton of patches were missing from the source), but that makes Legato unusable. Then I found out about Legato RO, and after another round of headaches and nonsense (Like the Yocto recipe not accepting READ_ONLY=1 during make and figuring out that Legato has to be built using the Yocto source, or else it won’t flash) it still doesn’t work, and honestly I have been banging my head into a wall this whole time. Does any of you guys have a solution/fix/whatever that can get me this problem sorted? I need full module functionality, and power loss resistance.
