Would you help to identify the modem model please?
I have a hardware which has a wavecom modem inside.
It responses:
at+cgmi
WAVECOM MODEM
at+cgmm
MULTIBAND 900E 1800
at+cgmr
543_09gg.Q2406A 1364028 020305 19:10
at+whwv
Hardware Version 4.75
at+wssw
a04_48gg.Q2406A 0006002CAB5DC7EA
at+wdop
Production Date (W/Y): 26/2006
ati
WAVECOM MODEM
MULTIBAND 900E 1800
ati3
ati4
Q:0 V:1 S0:000 S2:043 S3:013 S4:010 S5:008
+CR:0 +CRC:0 +CMEE:0 +CBST:0,0,1
+SPEAKER:0 +ECHO:0,1 &C:1 &D:1 %C:2
+IPR:115200 +ICF:3,4 +IFC:2,2
ati6
DATA RATES: AUTOBAUD,300,1200,1200/75,2400,4800,9600,14400
DATA MODES: T/NT,ASYNCHRONOUS
FAX CLASS: 1,2
Could you identify exact model name of that modem?
Is it possible to update wavecom software (OS?) on it?
Are there new OS versions for this model?
We have ~200 such a devices and got a serious problem which forces modem shut up and never answer on any request. We use it as a usual gsm/gprs modem and it’s a very strange situation.
WR, SwD.
Have you looked at the ‘Products’ pages - which one looks the most like the model you have?
Is it a true “modem” - ie, a packaged, end-user product - or is it a module?
Q2406 is the key: that is the GSM “engine” - look it up on the Products page…
Where did you get them?
Have you spoken to your supplier?
Modem is a built-in module.
Devices are sealed (I can’t look inside) and mostly on warranty, but problem is too frequent. We replaced more than 50 devices. Warranty is expires soon & we need to solve that problem without supplier - this would become OUR problem, not their.
Device has it’s own processor, i2c, rs232 & can communicate with integrated modem module.
I can program main device processor, but have access to modem via internal rs232 only.
The problem is: when it is hard to register in the gsm network, modem can stop answer to command +CREG? or +CFUN=1, usualy that is not fatal. After DTR on/off and some atz like commands it answers again. But sometimes after +CFUN=1 it stops answer forever. Also it can stop answer forever during standart start-up or shutting down, probably under the same hard network conditions. And this is a problem.
They not interested to solve that problem. AFAIU - too local problem. We still trying this way, but it takes too much time and no confidence in success.
Their common position - “What did you do with modem?! We have no such a problem!”
What can I say?
I have logs, logs show problem with modem.
We have other devices of other manufacturer, or other GSM modem, connected to problem device (it has RS232), we use the same i/o protocol & have no such a problem. So we consider - this is a problem of modem software. I’ve thought this can be a a well-known problem for Wavecom and there is a software upgrade for this model.
Take a look - I think I can’t do something wrong with modem by fallowing commands:
SET_DTR:
SET_DTR:
EMPTY_READ: 2 times (no income data found during timeout)
WRITE: [16]AT&FE0V1+CREG=0 (send command to modem)
EMPTY_READ: 49 times
READ: [6] (recieved from modem)
WRITE: [10]AT+CMEE=1
EMPTY_READ: 1 times
READ: [6]
WRITE: [10]AT+WAIP=1
EMPTY_READ: 1 times
READ: [6]
WRITE: [5]AT&W
EMPTY_READ: 15 times
READ: [6]
WRITE: [10]AT+CFUN=1 !!! (this is the last fatal command, but previous +CFUN=1 were successfull. What can I do wrong here or later?)
EMPTY_READ: 741 times (5 seconds time-out)
CLEAR_DTR:
EMPTY_READ: 851 times
SET_DTR:
module restart
SET_DTR:
EMPTY_READ: 2 times
EMPTY_READ: 4337 times
EMPTY_READ: 870 times
If I do not use +WAIP=1, &F, &W and +CFUN=1, modem fatally fails on start up or shutting down - I can’t guess.
Before fatal command we can find non-fatal same problems with network registration:
EMPTY_READ: 91 times
READ: [6]
EMPTY_READ: 344 times
READ: [6]
WRITE: [9]AT+CREG?
EMPTY_READ: 1 times
READ: [8]
+CREG:
READ: [8] 0,0
READ: [4]OK
EMPTY_READ: 2211 times
WRITE: [9]AT+CREG?
EMPTY_READ: 3 times
READ: [8]
+CREG:
READ: [8] 0,2
READ: [4]OK
EMPTY_READ: 2205 times
WRITE: [9]AT+CREG? (oops! no answer! but later we will get it)
EMPTY_READ: 2158 times
EMPTY_READ: 4342 times
(still no answer! but later we will get it)
