WMP 100 latest firmware file and upgrade guide
Hi everyone,
Can someone share the latest WMP100 firmware .wpk files?
I need R7.51.x or newer for my device and instructions on how to update it.
Thanks!
what is the current firmware on the WMP100?
Have you ever upgraded the firmware by AT+WDWL with XMODEM protocol?
did you PC install any developer studio software before for compiling OpenAT program? If yes, you can get the firmware there.
Hi jyijyi,
I have not upgraded the firmware so far.
I have also not installed any Developer Studio software on my PC.
do you the files?
BR, Ramin
you can upgrade the module via Airvantage server by Firmware over the air.
I need local solution, we need to upgrade locally.
why do you need to upgrade firmware for a module that has been end of life for so many years?
we have about 200 of theme. current FW is 7.47.6. we have network registration issues.
have you contacted distributor?
does it mean that the module working in the field for many years with FW 7.47.6, but now suddenly it does not work?
No, it connects to networks very late. it seems that there is bug with registration to the network. and for other provider it doesn’t registers.
i could not connect to theme.
is your module OK to connect UART to PC with XMODEM download?
module is ok. but it’s connected to other board. i can see that is tries to register to the network. but i connects so late after 40 seconds. i have check every thing i guess its because of module firmware.
can it be related to antenna problem?
I don’t think so. when it’s connects we can see signal level about 80.
If you use manual mode in at+cops, can it speed up the registration time?
